unsupported format Old JPEG (in TIFF)
Re: unsupported format Old JPEG (in TIFF)
What problem do you have?
ltdeta
sorry,
take a look on the Tif-file in the Zip-file linked below
http://www.file-upload.net/download-406 ... 2.zip.html
the format is Tiff with embedded old-Jpeg.
testing the BarcodeReader with this image i got the message "unsupported format Old JPEG (in TIFF)"
VintaSoftBarcode.NET SDK does not have built-in decoders for image files, SDK loads images from files using .NET decoders.
.NET 2.0/4.0 does not support TIFF files with OldJPEG and ZIP compressions.
You can use VintaSoftImaging.NET SDK to solve the problem. VintaSoftImaging.NET SDK can load any TIFF images.
ltdeta
i need to combine VintaSoftImaging.NET SDK and VintaSoftBarcode.NET SDK reading barcodes from "Old JPEG (in TIFF)"?
Yes.
Imaging SDK is using for reading images, Barcode SDK is using for reading barcodes from images.
ltdeta
can you explain "the way" simply?
Here is a snippet of code which shows how to load TIFF image with OldJPEG compression and read barcodes from the image:
' Important: You need Vintasoft.Barcode.dll,
' Vintasoft.Imaging.dll,
' to run this code.
Public Shared Sub ReadBarcodesUsingImaging(ByVal filename As String)
Dim images As New ImageCollection()
images.Add(filename)
' foreach images
For Each image As VintasoftImage In images
' get page Image
Dim pageImage As Image = image.GetAsBitmap()
' read barcodes
ReadBarcodesFromImage(pageImage)
' free resources
pageImage.Dispose()
Next
' free resources
images.ClearAndDisposeItems()
End Sub
Public Shared Sub ReadBarcodesFromImage(ByVal barcodeImage As Image)
' create barcode reader
Dim reader As New BarcodeReader()
' EAN13, Code 39, Code128 and DataMatrix barcodes are extracted
reader.Settings.ScanBarcodeTypes = BarcodeType.EAN13 Or BarcodeType.Code39 Or BarcodeType.Code128 Or BarcodeType.DataMatrix
' only horizontal barcodes are extracted
reader.Settings.ScanDirection = ScanDirection.Horizontal
' read barcodes from image
Dim infos As IBarcodeInfo() = reader.ReadBarcodes(barcodeImage)
If infos.Length = 0 Then
Console.WriteLine("No barcodes found.")
Else
Console.WriteLine(String.Format("{0} barcodes found:", infos.Length))
Console.WriteLine()
For i As Integer = 0 To infos.Length - 1
Dim info As IBarcodeInfo = infos(i)
Console.WriteLine(String.Format("[{0}:{1}]", i + 1, info.BarcodeType))
Console.WriteLine(String.Format("Value: {0}", info.Value))
Console.WriteLine(String.Format("Region: {0}", info.Region))
Console.WriteLine()
Next
End Sub-
ltdeta
