Version 7.2 of VintaSoftImaging.NET SDK has been released.
Version 7.2.9.1 of VintaSoftImaging.NET SDK has been released.
  • Fixed the bug in algorithm that extracts text from PDF page.
  • Fixed the bug in PDF encoder.
Version 7.2.11.1 of VintaSoftImaging.NET SDK has been released.
  • Improved the quality of image preview in image viewer when images are changed fast in the viewer.
  • Decreased the memory usage at rendering of PDF page which contains large images.
Version 7.2.12.1 of VintaSoftImaging.NET SDK has been released.
  • Optimized the memory usage when working with large images.
  • Improved the parser of PDF documents.
  • Fixed the bug in PdfGraphics.DrawString() method.
Version 7.2.13.1 of VintaSoftImaging.NET SDK has been released.
  • Improved the WpfThumbnailViewer control for compatibility with standard algorithm of tab navigation.
  • In JPEG decoder added the support for channel mapping for YcbCr color space.
  • Fixed the bug in parser of Type0 fonts.
Version 7.2.14.1 of VintaSoftImaging.NET SDK has been released.
  • In AnnotationDataCollection class added the AddFromStream(Stream, Resolution) method which allows to add any annotations (binary, XMP, Wang) from stream to the annotation collection.
  • AnnotationDemo is updated.
  • Fixed the bug in parser of TTF fonts.
  • Fixed a minor issue in parser of PDF image-resources.
  • Fixed a minor issue in PDF page renderer which appeared when progressive (dynamic) rendering was used.
Version 7.2.15.1 of VintaSoftImaging.NET SDK has been released.
  • The WpfImageViewer and WpfThumbnailViewer classes now implement the IDisposable interface, this allows to manage resources used by the class instance. Fixed not critical memory leaks in the classes.
  • Simplified work with the TextBox control of text annotation (see classes RectangularTextAnnotationTransformer and WpfRectangularTextAnnotationTransformer).
  • Added the ability to render the shadings defined by the Coons Patch Meshes or Tensor-Product Patch Meshes pattern.
  • Added the ability to render the appearance of fields of interactive forms (widget annotations).
Version 7.2.16.1 of VintaSoftImaging.NET SDK has been released.
  • Increased the rendering performance of PDF pages with large 1-bpp image masks.
  • Fixed the bug in encoding JPEG2000 images with high compression ratio.
  • Added the decoding support for JPEG2000 gray images with palette which contains colors only for 1 color channel.
Version 7.2.16.3 of VintaSoftImaging.NET SDK has been released.
  • Fixed the bug in StickyNoteAnnotation.
  • Fixed the bug in PDF decoder.
Version 7.2.16.5 of VintaSoftImaging.NET SDK has been released.
  • Fixed the bug in threads manager.
  • Fixed the bug in WANG decoder.
  • Fixed the bug in decoder of image resources in RGB12 format.
