i would like to catch the click event on a WpfImageViewer with PDF Coordinates (to tell where the user has clicked on a pdf page). Is it possible? I would also like to show some rectangles on the pdf pages programmatically. How can i do that?
Best Regards
Yimei
Click event on WpfImageViewer
Re: Click event on WpfImageViewer
Hi Yimei,
Yes, this is possible. For doing the task you need:i would like to catch the click event on a WpfImageViewer with PDF Coordinates (to tell where the user has clicked on a pdf page). Is it possible?
- Subscribe to the WpfImageViewer.MouseDown event
- In handler of WpfImageViewer.MouseDown event
- Convert a point in mouse (screen) coordinates into a point in the viewer coordinates using the WpfImageViewer.PointFromScreen method
- Convert a point in viewer coordinates into a point in the image coordinates using the WpfImageViewer.PointToImage method:
http://www.vintasoft.com/docs/vsimaging ... Image.html - Convert a point in image coordinates into a point in the PDF page coordinates using the PdfPage.PointToUnit method:
http://www.vintasoft.com/docs/vsimaging ... oUnit.html
This is also possible. Please read how to do this here: http://www.vintasoft.com/docs/vsimaging ... fPage.htmlI would also like to show some rectangles on the pdf pages programmatically. How can i do that?
waxwings
thanks for the reply. I tried the MouseDown event. It works however only on the right mouse click. I would like to work with the left mouse click event. Is it possible?
Best Regards
Yimei
Best Regards
Yimei
waxwings
hi Alex,
could you please also tell me what ist the measurement of the Point if i get it from the PointToImage method?
Best Regards
Yimei Liao
Best Regards
Yimei Liao
Hi Yimei,
There is no difference when you work with left or right mouse button. Could you share a snippet of your code?I tried the MouseDown event. It works however only on the right mouse click. I would like to work with the left mouse click event. Is it possible?
The PointToImage method (http://www.vintasoft.com/docs/vsimaging ... Image.html) returns point coordinate in pixels.could you please also tell me what ist the measurement of the Point if i get it from the PointToImage method?
waxwings
here is my code
Pdf_MouseDown is only triggered by the right mouse click.
Best Regards
Yimei Liao
here is my code
imageViewer.MouseDown += new MouseButtonEventHandler(Pdf_MouseDown);
private void Pdf_MouseDown(object sender, MouseEventArgs e)
Best Regards
Yimei Liao
Here is my code:
and it works correctly for left and right mouse buttons.
Please send working demo project which demonstrates the problem to support@vintasoft.com, we need reproduce your problem.
this.imageViewer1.MouseClick += new System.Windows.Forms.MouseEventHandler(this.imageViewer1_MouseClick);
this.imageViewer1.MouseDown += new System.Windows.Forms.MouseEventHandler(this.imageViewer1_MouseDown);
private void imageViewer1_MouseDown(object sender, MouseEventArgs e)
MessageBox.Show("MouseDown " + e.Button.ToString());
private void imageViewer1_MouseClick(object sender, MouseEventArgs e)
MessageBox.Show("MouseClick " + e.Button.ToString());
}Please send working demo project which demonstrates the problem to support@vintasoft.com, we need reproduce your problem.
waxwings
the MouseClick Event is not available. I would send you the example codes sortly.
Best regards
Yimei
Best regards
Yimei
waxwings
i have yet another problem. I have some pdf documents, each containing only one page. I open the pdfs one after another, while showing a Rectangular on each of them. Problem is that sometimes the Rectangular shows and sometimes not. It looks like a race condition to me. My codes are like
Best regards
Yimei
private void NextPdf_Click(){
openDocument(nextIndex);
showRectangular();
private void showRectangulars()
using (PdfGraphics graphics = PdfGraphics.FromPage(FocusedPage))
System.Drawing.PointF p = new System.Drawing.PointF((float)x, (float)y);
FocusedPage.PointToUnit(ref p);
System.Drawing.Color brushColor = System.Drawing.Color.FromArgb(0, 0, 0);
PdfBrush brush = new PdfBrush(brushColor, GraphicsStateBlendMode.Multiply);
PdfPen pen = new PdfPen(brushColor);
graphics.FillAndDrawRectangle(pen, brush, 100, 100, 200, 200);
imageViewer.Image.Reload(true);
private void OpenDocument(int index)
CloseDocument();
PdfDocumentController.AuthenticateRequest += new EventHandler<PdfDocumentOpenedEventArgs>(PdfDocumentController_AuthenticateRequest);
String filename = VM.getPdfName(index);
// try open in read-write mode
_documentStream = new FileStream(filename, FileMode.Open, FileAccess.ReadWrite);
catch (IOException)
// try open in read mode
_documentStream = new FileStream(filename, FileMode.Open, FileAccess.Read);
catch (IOException e)
Debug.Write(e);
return;
catch (Exception e)
Debug.Write(e);
return;
_document = PdfDocumentController.OpenDocument(_documentStream);
if (_document.IsEncrypted && _document.AuthorizationResult == AuthorizationResult.IncorrectPassword)
CloseDocument();
return;
catch (Exception e)
Debug.Write(e);
CloseDocument();
return;
_document.RenderingSettings.UseEmbeddedThumbnails = true;
imageViewer.Images.Add(_documentStream);
catch (Exception e)
Debug.Write(e);
CloseDocument();
return;
/// get the password from the AppConfiguration
void PdfDocumentController_AuthenticateRequest(object sender, PdfDocumentOpenedEventArgs e)
PdfDocument document = e.Document;
while (true)
AuthorizationResult authorization = document.Authenticate(AppConfiguration.PDF_DECRYPTION_KEY);
if (authorization == AuthorizationResult.IncorrectPassword)
Console.WriteLine("The password is incorrect.");
Console.WriteLine(authorization.ToString());
return;
Yimei
Hi Yimei,
I think your code has logical mistake. Please send working demo project which demonstrates the problem to support@vintasoft.com, we need reproduce your problem.i have yet another problem. I have some pdf documents, each containing only one page. I open the pdfs one after another, while showing a Rectangular on each of them. Problem is that sometimes the Rectangular shows and sometimes not. It looks like a race condition to me. My codes are like
