Scan only ONE page although multiple are in feeder?
pikarde
Post by pikarde »
I'm using vintasoft twain library V 5.
I have one of those "Bad" Scanner, Brother MFC-8220 (Shows Twain Version 1.9). When scanning more than one page in the feeder, only the last one will show up.
Is it possible to scan only page from the feeder although more than one is in the feeder or is that something automated by the printer that we can't control?
The idea is that if we can't make the multiple-page scan work without the scanner UI, maybe we can scan one page at a time and simulate regular feeder behavior?
Sam
Re: Scan only ONE page although multiple are in feeder?
Hello Sam,
Sorry for a delay.
Yes, with "bad" scanners you should try to disable feeder and scan images one by one.
fox750
Post by fox750 »
I also have this problem, this is the sequence of events:
- I placed 2 pages of ADF
- start acquire
- get the first image (correctly)
- get the second image, and the first one is also a copy of second
- result 2 pages with the content of the second scanned page
If you get the first one correctly how it can happen that it is overwritten? Is this because of twain?
Maybe you can make a smart work around ;)
What scanner do you have? Please generate log-file of scanner's work and send it to support@vintasoft.com.
Here are steps which you should do to generate a log-file of scanner's work:
  • Run your application.
fox750
Post by fox750 »
I just sent the e-mail with detailed info.
In case you need more details do not hesitate to ask :-)
fox750
fox750
Post by fox750 »
Problem solved on VintaSoftTwain.NET Library version 5.0.5.1.
