Version 6.0 of VintaSoftTwain ActiveX has been released.
Version 6.0.12.1 of VintaSoftTwain ActiveX has been released.
Version 6.0.12.1 of VintaSoft Twain ActiveX has been released.
What's new in this version:
  • Defined the formats for values of PdfEncoder_DocumentCreationDate and PdfEncoder_DocumentModificationDate properties. Information about supported formats can be found here: https://www.vintasoft.com/docs/vstwain/ ... nDate.html
Version 6.0.13.1 of VintaSoftTwain ActiveX has been released.
Version 6.0.13.1 of VintaSoft Twain ActiveX has been released.
  • Fixed the bug in image processing commands Crop and ResizeCanvas.
Version 6.0.14.3 of VintaSoftTwain ActiveX has been released.
Version 6.0.14.3 of VintaSoft Twain ActiveX has been released.
  • Fixed the bug in AcquiredImages_Save method. The error could occur during image saving to a PDF document if PDF document date/time is specified.
Version 6.0.15.1 of VintaSoftTwain ActiveX has been released.
Version 6.0.15.1 of VintaSoft Twain ActiveX has been released.
  • Added the Device_Caps_WorkDirectly property, which allows to specify that the device must try to get / set the capability value even if capability is not present in device capability list.
Version 6.0.16.1 of VintaSoftTwain ActiveX has been released.
Version 6.0.16.1 of VintaSoft Twain ActiveX has been released.
  • Improved the algorithm of AcquiredImages_Deskew method.
Version 6.0.17.1 of VintaSoftTwain ActiveX has been released.
Version 6.0.17.1 of VintaSoft Twain ActiveX has been released.
  • Improved the algorithm of VSTwain.Device_Cap_DefaultValue property.
  • Improved the algorithm of VSTwain.Device_Cap_ValueContainerType property.
  • Improved the algorithm of VSTwain.Device_GetSupportedResolutions method.
