Post Scan Event is called twice
vanilla Y
Post by vanilla Y »
After I scan a document, it goes twice to the Post Scan event.
First time is good, but then immediately it enters another time to this event.
What can be the reason? :roll:
I'm registered only once to the event:
VSTwainDocument.PostScan += new AxVSTWAINLib._IVintaSoftTwainEvents_PostScanEventHandler(VSTwainDocument_PostScan);
Thanks ahead,
Vanilla
Re: Post Scan Event is called twice
Hello Vanilla,
What scanner do you have? I think you have duplex scanner with enabled duplex. PostScan event occurs for each side of the scanned page.
vanilla Y
Post by vanilla Y »
My scanner doesn't have duplex option. :(
In my code, I do the following check:
if (m_bIsDuplex)
if (VSTwainDocument.Duplex != 0)
VSTwainDocument.DuplexEnabled = 1; //scan the doc from both sides
else VSTwainDocument.DuplexEnabled = 0; //in my case, goes to this line
VSTwainDocument.Acquire();
Should I do another thing to disable the duplex option?
Vanilla
Hello Vanilla,
Please send the following information to support@vintasoft.com:
1. What scanner do you use?
2. Log-file generated by VintaSoftTwain.NET Library
Here are steps which you should do to generate a log-file of scanner's work:
1. Set the IsLoggingEnabled property to True before the StartDevice method.
2. Set the path to log-file with the LogFilePath property if path "c:\vstwain.log" is not accessible by your application.
3. Run your application.
4. Send us a log-file and detailed description of the problem.
vanilla Y
Post by vanilla Y »
As you said, I added the following:
VSTwainDocument.IsLoggingEnabled = 1;
VSTwainDocument.StartDevice();
VSTwainDocument.LogFilePath = "c:\vstwain.log";
I scanned a document and this is what I've got in c:\vstwain.log:
9:35:36.750 StopDevice
9:35:36.750 OWM: 92933250 129 0 101367484 0
9:35:36.750 OWM2
9:35:36.750 OWM8
9:35:36.750 OWM: 92933250 131 0 101367524 0
9:35:36.750 OWM2
9:35:36.765 OWM8
9:35:36.765 OWM: 92933250 1 0 101367464 0
9:35:36.765 OWM2
9:35:36.765 OWM8
9:35:36.765 OWM: 92933250 5 0 0 0
9:35:36.765 OWM2
9:35:36.765 OWM8
9:35:36.765 OWM: 92933250 3 0 0 0
9:35:36.765 OWM2
9:35:36.765 OWM8
9:35:36.765 ODSM1
9:35:36.765 ODSM2
9:35:36.765 C:\WINDOWS\TWAIN_32.DLL
9:35:36.765 ODSM2-1
9:35:36.765 ODSM20
9:35:36.984 StartDevice - 50047 92933250 20319114
--------- log till here
I'm using Epson perfection 1660.
Do you have a clue?
Thanks a lot!!!
Vanilla
Hello Vanilla,
Information you provided is not full. Please send full log-file to support@vintasoft.com.
