New features request for version 9.0 of VintaSoft Imaging .NET
The following features are being considered for inclusion in version 9.0 of VintaSoft Imaging .NET SDK:
  • .NET Core 3 support for Windows.
  • DOCX decoder.
  • Ability to convert DOCX file to PDF document.
If you have any idea or suggestion, please write it here.
miromr
Re: New features request for version 9.0 of VintaSoft Imaging .NET
Post by miromr »
- PAdES signature?
- undo/redo for all tools
Thank you for suggestions.
miromr wrote: Sun Sep 09, 2018 6:38 pm - PAdES signature?
PAdES signatures will be available this year in version 8.7.x.
miromr wrote: Sun Sep 09, 2018 6:38 pm - undo/redo for all tools
Please be more specific. What functionality do you need?
miromr
Post by miromr »
Thank you
I thought this would be the Undo / Redo operation programmed to the component level. In PDF Editor, I work with the open pdf document and use various VisualTools. I'm working with text for a while, then I add annotations, then somewhere I mark editorial tags. And before I save the document, I decide to return some of the changes. It's about Undo / Redo to include all tools (_annotationTool, _contentXObjectTool, _textSelectionTool, _removeContentTool and _contentEditorTool) so the programmer does not have to worry about managing changes.
I simply call the Undo () or Redo ()
Miro
Hello Miro,
Thank you for explanation. We will analyze your request and will try to provide you necessary functionality.
Hello Miro,
We analyzed your request and have found that we can develop functionality for undo/redo in PDF document but for general case the architecture will be very complex. Undo/redo architecture is open and we think that the best way in this situation is to create necessary code in end-user application.
