I'm adding some images and text to an image. Works fine when I add images but when I add a TextLineFigure and I try and render, I get an error, 'Object is not part of this document.' I can see the TextLineFigure in the FigureViewCollection so not sure where the issue is.
Thanks!
Error When Rendering
Re: Error When Rendering
Please send us (to a support@vintasoft.com) a simple working aplication, which allows to reproduce the problem, if you cannot solve the problem by yourself.
A TextLineFigure object has a PdfFont object, which is used for text drawing. Please make sure that the PdfFont object references to a PDF font in your PDF document.tplambeck wrote: Sat Jul 13, 2019 8:57 pm I'm adding some images and text to an image. Works fine when I add images but when I add a TextLineFigure and I try and render, I get an error, 'Object is not part of this document.' I can see the TextLineFigure in the FigureViewCollection so not sure where the issue is.
Thank you Alexander, that explains the underlying issue. The PDF is image based and has no PdfFonts associated with it so I am creating a new PDFFont object. How do I add the PdfFont to the document? Looks like the Fonts collection is read only.
Thanks again!
Thanks again!
Please read how to create PDF font here: https://www.vintasoft.com/docs/vsimagin ... ument.htmltplambeck wrote: Mon Jul 15, 2019 6:03 pm How do I add the PdfFont to the document? Looks like the Fonts collection is read only.
