delete selected pages in sourcefile
gunnuy
Post by gunnuy »
I'd like to enable the user to have thumbnail viewer selected pages being deleted in the source file.
My approach ends here:
Dim selectedImage As VintasoftImage() = Nothing
Dim selectedIndices As Integer() = .thumbnailViewer1.SelectedIndices.ToArray()
If _myCollection.Count > 0 Then
    selectedImage = New VintasoftImage(selectedIndices.Length - 1) {}
    For i As Integer = 0 To _myCollection.Count - 1
        selectedImage(i) = .thumbnailViewer1.Images(_myCollection(i))
        Dim image As VintasoftImage = selectedImage(i)
        image.Dispose() ' problem is here
    Next
How do I write back those remaining pages to the source file?
A code sample would greatly be appreciated!
Thank you and Best
Guenther
Re: delete selected pages in sourcefile
Hi Guenter,
Here is example that shows how to delete selected thumbnails in thumbnail viewer and save image in thumbnail viewer to a file. As filename can be used the name of new file or source file.
Private Sub RemoveSelecedImagesAndSave(thumbnailViewer As ThumbnailViewer, filename As String)
    Dim indexes As Integer() = thumbnailViewer.SelectedIndices.ToArray()
    Dim removingImages As New List(Of VintasoftImage)
    For Each index As Integer In indexes
        removingImages.Add(thumbnailViewer.Images(index))
    Next
    thumbnailViewer.Images.RemoveRange(indexes)
    For Each image As VintasoftImage In removingImages
        image.Dispose()
    Next
    Dim encoder As EncoderBase = AvailableEncoders.CreateEncoder(filename)
    encoder.SaveAndSwitchSource = True
    thumbnailViewer.Images.SaveSync(filename, encoder)
End Sub
gunnuy
Post by gunnuy »
Hallo Alex,
works as intended, thanks a lot!!
