My company has 5 printers, which are multifunctional, these are the models:
Kyocera M3655
Kyocera M2640dw
Kyocera 306CI
SAMSUNG M4080FX
SAMSUNG M4020
Is it possible to use the SDK to scan?
Sorry my english isn't so good.
Thank you so much.
scan with multifunction on the network
Re: scan with multifunction on the network
Hello Paulo,
List of tested scanners, which we or our customers tested, can be found here: https://www.vintasoft.com/forums/viewforum.php?f=19
VintaSoft Twain .NET SDK will work with your scanners if you have TWAIN/WIA driver for your scanner.
Please download the evaluation version of VintaSoft Twain .NET SDK from our web site, evaluate the SDK, check if SDK suits your needs and write our support team at support@vintasoft.com if you will have any question or problem.
