Problem description:
Some times when we run OCR we don't get a very good interpretation. For example "xxxx@xxx.se" became "xxxx(@xxx.se" or "i" became "|"
Solution
There is OcrResultsEditor.RemoveObjects that are used to remove.
We need to be able also to replace objects text. For example replace all words that contains (@ to @.
How can we achieve this?
Replace objects text of OcrObject
Re: Replace objects text of OcrObject
Hello Benjamin,
Please read how to obtain and edit the OCR results here:
https://www.vintasoft.com/docs/vsimagin ... sults.html
I couldn't find the solution in the documentation and therefore I write this for those who read this in the future.
In order to replace text you must use SetObjectText and cast OcrObject to OcrTextObject .
ocrResultsEditor.SetObjectText((OcrTextObject)ocrObject, "newText");
BenjaminA wrote: Mon Sep 02, 2019 1:46 pm I couldn't find the solution in the documentation and therefore I write this for those who read this in the future.
Please see how to filter OCR results here:
https://www.vintasoft.com/docs/vsimagin ... ditor.html
