Version 12.1 of VintaSoft Barcode .NET SDK has been released.
What's new in this version:
  • .NET development
    • Added the support for .NET Core 3 for Windows, macOS and Linux.
    • Created .NET Core assembly Vintasoft.WpfBarcode.dll, which can be used in .NET Core WPF project.
    • Discontinued support of .NET Framework 2.0. Now SDK supports .NET Framework 4+ and 3.5.
    • "Edition for Windows" now substitutes former "Standard edition" and "Standard+WPF edition".
    • Added the ability to recognize and generate ISBT 128 and ISBT 128 Data Matrix barcodes.
    • Added the ability to recognize and generate HIBC LIC 128, HIBC LIC 39, HIBC LIC Aztect Code, HIBC LIC Data Matrix and HIBC LIC QR Code barcodes.
    • Added the BarcodeWriter.SaveBarcodeAsImage method, which allows to save generated barcode to a file or stream in PNG, BMP or SVG format.
    • Created WinForms and WPF demo applications for .NET Core.
  • Web development
    • Added .NET Core 3 support in the platform-independent .NET Core web service for recognizing and generating barcodes.
    • Added .NET Core 3 support in ASP.NET Core Web API service for recognizing and generating barcodes.
    • Updated the AspNetCoreBarcodeDemo project for compatibility with ASP.NET Core 3.
Version 12.1.1.1 of VintaSoft Barcode .NET SDK has been released.
  • Now web assemblies use Vintasoft.Shared.Web.dll assembly version 1.5.
  • Changed and impoved algorithm that sorts results of barcode recogniton.
Version 12.1.1.3 of VintaSoft Barcode .NET SDK has been released.
  • Improved the algorithm that recognizes Code128 barcodes.
Version 12.1.1.5 of VintaSoft Barcode .NET SDK has been released.
  • Added the ability to save barcode image to a PNG or BMP file without usage GDI+ (the BarcodeWriter.SaveBarcodeAsImage method in .NET Core version of Vintasoft.Barcode.dll).
  • Fixed the bug in licensing algorithm of Vintasoft.XamarinBarcode.Android.dll.
Version 12.1.2.1 of VintaSoft Barcode .NET SDK has been released.
  • Fixed the bug in algorithm that generates DataMatrix barcode with Unicode value.
  • Fixed the bug in algorithm that verifies optional checksum in Code39 barcode.
Version 12.1.3.1 of VintaSoft Barcode .NET SDK has been released.
  • Improved the algorithm that recognizes PDF417 compact barcodes.
  • Improved the algorithm that recognizes barcodes in automatic mode.
  • Improved the source codes of demo projects for Xamarin.Android.
Version 12.1.3.3 of VintaSoft Barcode .NET SDK has been released.
Version 12.1.4.1 of VintaSoft Barcode .NET SDK has been released.
  • Added the support for .NET 5 Preview 6.
  • End of support for .NET Core 3.0, now the SDK supports .NET Core 3.1. The support for .NET Core 3.0 is dropped off because starting from May 3, 2020 Microsoft ended the support for .NET Core 3.0 and the information about this fact appeared on Microsoft's web site: https://dotnet.microsoft.com/platform/support/policy/dotnet-core. If you are our client and you still need the support for .NET Core 3.0, please contact us to discuss the situation.
  • End of support for .NET Framework 4.0, 4.5 and 4.5.1, now the SDK supports .NET Framework 4.8, 4.7, 4.6, 4.5.2 and 3.5. The support for .NET Framework 4.0, 4.5 and 4.5.1 is dropped off because starting from January 12, 2016 Microsoft ended the support for .NET Framework 4.0, 4.5 and 4.5.1 and the information about this fact appeared on Microsoft's web site: https://docs.microsoft.com/en-us/lifecycle/faq/dotnet-framework. If you are our client and you still need the support for .NET Framework 4.0, 4.5 or 4.5.1, please contact us to discuss the situation.
