Overriding Cursors
IntegraMike
Overriding Cursors
Post by IntegraMike »
Hi, I'm looking to overwrite the cursors for the annotation tool for specific annotation types (ex. Replace the normal cursor and action cursor for the PdfAnnotationTool to reflect the annotation that will be created by the tool is an ink annotation, etc.). I can get the icon replaced, but for some reason it doesn't always get reflected in the viewer. Also, updating the action cursor doesn't seem to be doing anything (it always goes back to the cross).
So far as I can tell, the cursor being displayed is the ImageViewer's cursor property, but that seems to be set in the background by active tools etc. Is there a way for me to force the viewer to take the cursor off of a specific tool or otherwise lock the ImageViewer's cursor image?
Of note, I have tried overriding the cursor properties in the ImageViewer, PdfAnnotationTool, and CompositeVisualTool and I that gets things close (specifically the ImageViewer works the best) however it dramatically slows down drawing ink annotations (I assume because it's constantly flipping back and forth between cursors under the hood somewhere). It also sometimes keeps my cursor around even when I do the following:
public class MyImageViewer : ImageViewer
	private Cursor _lockCursor = null;
	public void LockCursor(Cursor lockCursor)
		_lockCursor = lockCursor;
	public override Cursor Cursor
		get
			if (_lockCursor != null)
				return _lockCursor;
				return base.Cursor;
		set => base.Cursor = value;
And then when I want my cursor to override everything I call LockCursor(newCursor) and when I want it to go back to normal operation I call LockCursor(null). Sometimes I'll switch to a different tool and the previously locked cursor comes back from somewhere I haven't been able to find.
Thanks!
Re: Overriding Cursors
Hi Mike,
It is bad idea to lock cursor of image viewer because there is a lot of objects, which change cursor in image viewer.
Here is "small list" of object, which can change cursor in image viewer: Please change cursor in all used objects instead of "locking" cursor of image viewer.
IntegraMike
That was actually what I tried to do first, but there's something going on in the background that is occasionally bringing back cursors that aren't valid for the tool (especially when hovering over locked annotations for some reason). I've gone back to that and by adding the hack of in the mouse move event for the annotation tool setting the ImageViewer's cursor to the cursor of the annotation viewer. Currently we don't have custom action cursors or this wouldn't work, but it seems to get things going until I have time to go back and fix this the right way. I think there's probably something going awry in the SetCursor/RestoreCursor methods that I assume are being used internally when the cursor is being updated based on a tool, so maybe overriding those will do it, but that's just a guess.
Thanks for the help!
Thank you for information.
If you cannot solve problem by yourself, please send us (to support@vintasoft.com) a small project, which allows to reproduce the problem, and we will try to improve your code.
