I am following your example for scanning the top part of a page. I am testing on 2 scanners. One is a Canon and the other is a Fujitsu Fi-7160. It works fine on the Canon, but the Fujitsu scans the entire page every time. Here is the code that I believe is meaningful:
                    device.UnitOfMeasure = UnitOfMeasure.Inches;
                    device.ImageLayout.Reset();
                    device.ImageLayout.Set(0f, 0f, 8.5f, 5f);
                    device.Acquire();
Here is the full code:
    class Program
        /// The main program.
        /// <param name="args"></param>
            Console.WriteLine("Starting...");
            TwainGlobalSettings.Register("S******", "****@******.com", "****-**-**", "*****");
                Console.WriteLine("Select a scanner by entering its number.  Press x to quit.");
                DeviceManager deviceManager = new DeviceManager();
                deviceManager.Open();
                Scan(deviceManager);
            catch (Exception e)
                Console.WriteLine(e.Message);
            finally
                Console.ReadLine();
        /// Scans an image.
        /// <param name="deviceManager"></param>
        private static void Scan(DeviceManager deviceManager)
            Device device = null;
                ListDevices(deviceManager);
                var selected = GetSelectedScanner(deviceManager);
                if (selected >= 0)
                    device = deviceManager.Devices[selected];
                    device.Open();
                    device.ShowUI = false;
                    SubscribeToDeviceEvents(device);
                    device.Acquire();
            catch
                // if device is found
                if (device != null)
                    // if device is opened
                    if (device.State >= DeviceState.Opened)
                        // close the device
                        device.Close();
                    UnsubscribeFromDeviceEvents(device);
                throw;
        /// Lists the devices.
        private static void ListDevices(DeviceManager deviceManager)
            var devices = deviceManager.Devices;
            for (int i = 0; i < devices.Count; i++)
                if (!devices[i].Info.IsWIA)
                    Console.WriteLine($"[{(i + 1).ToString("d2")}] {devices[i].Info.ProductName}");
        /// Allows the user to select a scanner.
        /// <returns>
        /// If a scanner is selected, returns the index of the selected scanner and -1 otherwise.
        /// </returns>
        private static int GetSelectedScanner(DeviceManager deviceManager)
            do
                Console.WriteLine("");
                Console.Write("Enter the number of the scanner to select it: ");
                var enteredString = Console.ReadLine();
                if (int.TryParse(enteredString, out int scannerNumber))
                    scannerNumber--;
                    if ((scannerNumber >= deviceManager.Devices.Count)
                        || (scannerNumber < 0))
                        Console.WriteLine("Invalid number.  Try again.");
                        return scannerNumber;
                else if (string.Compare("x", enteredString, true) == 0)
                    return -1;
                    Console.WriteLine($"{enteredString} is not a number.");
            } while (true);
            deviceManager.Close();
        /// Image is acquired.
        private static void device_ImageAcquired(object sender, ImageAcquiredEventArgs e)
            var path = System.IO.Path.Combine(System.IO.Directory.GetCurrentDirectory(), $"image{DateTime.Now.ToString("yyyy-MM-dd HH-mm-ss")}.bmp");
            e.Image.Save(path);
            Process.Start(path);
            // dispose the acquired image
            e.Image.Dispose();
        /// Scan is completed.
        private static void device_ScanCompleted(object sender, System.EventArgs e)
            Console.WriteLine("Scan is competed.");
            Console.WriteLine("Press enter to exit");
            Console.Read();
        /// Scan is canceled.
        private static void device_ScanCanceled(object sender, System.EventArgs e)
            Console.WriteLine("Scan is canceled.");
            Console.Read();
        /// Scan is failed.
        private static void device_ScanFailed(object sender, ScanFailedEventArgs e)
            Console.WriteLine(string.Format("Scan is failed: {0}", e.ErrorString));
            Console.Read();
        /// Called when the scan is finished.
        /// <param name="sender"></param>
        /// <param name="e"></param>
        private static void device_ScanFinished(object sender, System.EventArgs e)
            Device device = (Device)sender;
            // unsubscribe from device events
            // if device is not closed
            if (device.State != DeviceState.Closed)
                // close the device
                device.Close();
        /// Subscribes to the device events.
        /// <param name="device"></param>
        private static void SubscribeToDeviceEvents(Device device)
            device.ImageAcquired += new System.EventHandler<ImageAcquiredEventArgs>(device_ImageAcquired);
            device.ScanCompleted += new System.EventHandler(device_ScanCompleted);
            device.ScanCanceled += new System.EventHandler(device_ScanCanceled);
            device.ScanFailed += new System.EventHandler<ScanFailedEventArgs>(device_ScanFailed);
            device.ScanFinished += new System.EventHandler(device_ScanFinished);
        /// Unsubscribes to the device events.
        private static void UnsubscribeFromDeviceEvents(Device device)
            device.ImageAcquired -= new System.EventHandler<ImageAcquiredEventArgs>(device_ImageAcquired);
            device.ScanCompleted -= new System.EventHandler(device_ScanCompleted);
            device.ScanCanceled -= new System.EventHandler(device_ScanCanceled);
            device.ScanFailed -= new System.EventHandler<ScanFailedEventArgs>(device_ScanFailed);
            device.ScanFinished -= new System.EventHandler(device_ScanFinished);
Steve
