How can make drag and drop thumbnail UI to change the sequence of the pages
satish.trivedi
Post by satish.trivedi »
Using thumbnail how we can select and drag and drop pages (swap the document page)?
Re: How can make drag and drop thumbnail UI to change the sequence of the pages
Current version (12.2.7.1) of Vintasoft web thumbnail viewer does not allow to swap pages in viewer using drag-and-drop.
chintan.shah
Post by chintan.shah »
How would we get all thumbnails through Javascript, so we our self develop custom code to get and make thumbnail drag and drop.
Please refer below URL. Like this, we want it for thumbnails to work. So we can change the sequence of the thumbnails and then later we can save the document physically as per changed sequence.
https://jqueryui.com/sortable/#display-grid
Below is the high level code which we are using it to get the each thumbnail but it is not giving correct thumbnail. It is giving current visible document's big image:
test = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerJS(
      docViewerSettings).get_ThumbnailViewer().get_Images().getImage(3).getImageAsBase64String();
Chintan Shah
Hi Chintan,
Current version does not have web API that allows to get thumbnails as a base64-string.
We will add the ability to sort thumbnails (using drag-and-drop) in web thumbnail viewer in near time (I think in 2 weeks).
chintan.shah
In which version should we expect? Any date?
Chintan Shah
Hi Chintan,
We revised our plans and now the ability to sort thumbnails (using drag-and-drop) in web thumbnail viewer will be available in VintaSoft Imaging .NET SDK 12.3. We plan to release version 12.3 in November 2023.
chintan.shah
Thank you Alex for accommodating requested changes.
May we know which date in November, 2023?
Microsoft will release .NET 8 on November 14, 2023.
We plan to release VintaSoft Imaging .NET SDK 12.3 with .NET 8 support in 1-2 weeks after release of .NET 8.
Hi Chintan,
VintaSoft Imaging .NET SDK 12.3 has been released today and now VintaSoft Web Thumbnail Viewer allows to rearrange thumbnails using the drag-and-drop operation.
