Create Annotation on Righ click of web document viewer
jwalit.katira
Post by jwalit.katira »
I have created annotation on contextmenu_showing method but the annotation in not proper placed in same location where mouse is right clicked , I have also used imageViewer.transformPointFromScreenToControl method , it is working in some tiff file but not working in all tiff and PDF files, it shows wrong position
Below is my code
 function __annotationContextMenu_showing(event, eventArgs) {
      // get the document viewer
      var docViewer = this.get_RootControl();
      // if document viewer exists
      if (docViewer != null) {
        var position = eventArgs.position;
        var viewer = docViewer.get_ImageViewer();
        var annotationVisualTool = viewer.get_AnnotationVisualTool();
        let newposisiton = imageViewer.transformPointFromScreenToControl(
          position.x,
          position.y
        let imageAnnotation =
          new Vintasoft.Imaging.Annotation.UI.WebReferencedImageAnnotationViewJS();
        imageAnnotation.set_Url("https://demos.vintasoft.com/AspNetCoreDocumentViewerDemo/Images/VintaSoftLogo.png")
          imageAnnotation.set_Location(newposisiton.x, newposisiton.y);
        imageAnnotation.set_Size(25, 25);
        imageAnnotation.set_Border(false);
        imageAnnotation.set_CanResize(false);
        imageAnnotation.set_CanRotate(false);
        imageViewer.addAndBuildAnnotation(imageAnnotation);
        // set annotation under mouse cursor as focused annotation
        AnnotationVisualTool.set_FocusedAnnotationView(imageAnnotation);
Jwalit Katira
Re: Create Annotation on Righ click of web document viewer
Hello Jwalit,
The WebAnnotationViewJS.set_Location function (https://www.vintasoft.com/docs/vsimagin ... ation.html) sets the annotation location, in device-independent units (1/96th inch per unit).
Please transfer point from the control space to the annotation space (1/96th inch per unit) using the WebAnnotationViewerJS.transformPointFromControlToDip function (https://www.vintasoft.com/docs/vsimagin ... ToDip.html).
Also please remember that the location of WebReferencedImageAnnotationViewJS object is located in the center of image annotation.
jwalit.katira
Thanks Alex , it is working
