We are getting error from .net core webapi "Cannot create decoder for 1.jpg file" when we run API code in docker linux , Same code is working fine when we run api as normal HTTP
can you check the issue
Jwalit Katira
Cannot create decoder for 1.jpg file in linux docker
jwalit.katira
Re: Cannot create decoder for 1.jpg file in linux docker
Hello Jwalit,
JPEG decoder is internal decoder and it is stored in Vintasoft.Imaging.dll, i.e. JPEG decoder is always available.
Please check that "1.jpg" file is really JPEG file.
If you are loading file from stream, please check that stream position is 0.
