Version 14.3 of VintaSoft Barcode .NET SDK has been released.
What's new in this version:
  • Added the ability to recognize and generate Japan Post barcodes.
  • Added the ability to recognize and generate Italian Post 2 of 5 barcodes.
  • Now the barcode generator can generate vector representation of barcode with barcode text (for example EAN-13 barcode with text under barcode). Previously the barcode generator was able to generate vector representation of barcode without barcode text only.
  • Now the barcode generator can generate SVG-image of barcode with barcode text (for example EAN-13 barcode with text under barcode). Previously the barcode generator was able to generate SVG-image of barcode without barcode text only.
  • Now ISO15415 barcode print quality test can return the modulation matrix of analyzed barcode. The modulation matrix can be used to identify problems in printed barcode.
  • Increased the recognition performance of QR barcodes up to 20%.
  • Increased the recognition performance of DataMatrix barcodes up to 20%.
  • Improved the recognition of 1D and PDF417 barcodes on images with low quality.
  • BarcodeDemo: Added the ability to view the modulation matrix for a 2D barcode if the barcode was verified using ISO15415 barcode print quality test.
Version 14.3.1.1 of VintaSoft Barcode .NET SDK has been released.
  • Improved the algorithm that recognizes EAN barcodes.
Version 14.3.3.1 of VintaSoft Barcode .NET SDK has been released.
  • Vintasoft Web Barcode service now can recognize barcodes in image that is loaded from URL.
Re: Version 14.3 of VintaSoft Barcode .NET SDK has been released.
Version 14.3.4.1 of VintaSoft Barcode .NET SDK has been released.
  • Improved the algorithm that cancels barcode recognition. Now the ReaderSettings.RecognitionTimeout property can be used on any platform. Previosly the ReaderSettings.RecognitionTimeout thrown exception in .NET Core 3+ and .NET 5+ because Thread.Cancel method is deprecated in .NET Core 3+ and .NET 5+.
  • Added the ability to recognize DataMatrix barcodes from mirrored images.
  • Added the ReaderSettings.SearchMirrored2DBarcodes property that allows to enable/disable recognition of mirrored 2D barcodes.
Version 14.3.5.1 of VintaSoft Barcode .NET SDK has been released.
  • The Vintasoft.Barcode.ImageSharp assembly now references SixLabors.ImageSharp 3.1.4 assembly. Previously, the Vintasoft.Barcode.ImageSharp assembly referred to the SixLabors.ImageSharp 3.0.1 assembly.
