Version 12.4 of VintaSoft Imaging .NET SDK has been released.
The new version 12.4 of VintaSoft Imaging .NET SDK and Plug-ins has been released!
What's new in VintaSoft Imaging .NET SDK 12.4:
  • .NET development
    • Added the decoder for NDPI and VMS (Hamamatsu) image files.
    • Added multithreading in algorithm that decodes TIFF image with JPEG compression - this change significantly increased the algorithm performance.
    • Added the ability to use fast scarolling of images in image viewer.
    • Demo applications:
      • Added the ability to view NDPI and VMS (Hamamatsu) image files in LargeImageViewerDemo, ImagingDemo and WpfImagingDemo demo projects.
    • Fixed several non-critical bugs.
What's new in VintaSoft Office .NET Plug-in 4.4:
  • .NET development
    • Added the ability to convert PDF document to a DOCX document.
    • Added the ability to open secured DOCX and XLSX documents.
    • Added the support for new types of charts: Bubble, Stock, Combined, 3D Bubble, 3D Line, 3D Column, 3D Area, 3D Stacked Area.
    • Created WinForms-control SpreadsheetDocumentEditorControl and WPF-control WpfSpreadsheetDocumentEditorControl - each control is a fully featured XLSX document editor.
      • Significantly simplified code of SpreadsheetEditorDemo/WpfSpreadsheetEditorDemo project because project now uses the SpreadsheetDocumentEditorControl control.
  • Web development
    • Added the ability to open secured DOCX and XLSX documents in web document viewer.
What's new in VintaSoft PDF .NET Plug-in 9.4:
  • .NET development
    • Now PDF/A-1b converter can convert PDF documents, which contain OpenType fonts.
    • Improved the algorithm of PDF/A converter.
    • Improved the algorithm that allows to remove unnecessary content from a PDF document (PdfDocumentCleanupCommand class).
    • Improved the algorithm that compresses PDF document (PdfDocumentCompressorCommand class).
    • Significantly reduced the memory usage when rendering a PDF page that contains a large amount of vector content.
    • Fixed the bug in algorithm that decodes LZW data.
    • Fixed the bug in algorithm that renders FreeFormGouraudShadedTriangleMesh pattern.
    • Fixed several minor bugs in algorithm that renders a PDF page.
What's new in VintaSoft Annotation .NET Plug-in 12.4:
  • Web development
    • Now the visual tool WebMagnifierToolJS allows to magnify image with annotations. Previously the visual tool was able to magnify image only.
    • Added properties LoadAnnotationsOnlyForDisplayedImages and LoadAnnotationsOnlyForVisibleImages to the WebAnnotationViewerJS class.
What's new in VintaSoft JBIG2 .NET Plug-in 7.4:
  • .NET development
    • Increased the performance of JBIG2 decoder up to 20%.
    • Increased the performance of JBIG2 encoder up to 15%.
    • Fixed the bug in algorithm that decodes data of JBIG2 image.
What's new in VintaSoft JPEG2000 .NET Plug-in 8.4:
  • .NET development
    • Increased the performance of JPEG2000 decoder up to 15%.
    • Improved the algorithm that decodes JPEG2000 file, which does not conform to JPEG2000 standard.
    • Fixed the bug in algorithm that decodes data of JPEG2000 image.
What's new in VintaSoft OCR .NET Plug-in 7.4:
  • .NET development
    • The used Tesseract OCR engine has been updated to version 5.3.4.
What's new in VintaSoft DICOM .NET Plug-in 5.4:
  • .NET development
    • Updated DICOM types and metadata to comply with DICOM 2023 specification.
Version 12.4.1.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the smoothness of scrolling for large images in WinForms/WPF image viewer.
  • Web development
    • Improved the algorithm that initializes the annotation list panel in web document viewer.
  • .NET development
    • Fixed the bugs in the algorithm that renders chart in spreadsheet editor control.
    • Fixed the bugs in the algorithm that edit chart in spreadsheet editor control.
Version 12.4.2.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in TIFF decoder.
  • Web development
    • Improved the JavaScript code for compatibility with "Content-Security-Policy".
  • .NET development
    • Added enumeration Vintasoft.Imaging.Office.Spreadsheet.StandardChartType, which contains names of "standard" XLSX charts.
Version 12.4.3.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Added the ability to set rendering settings for thumbnails in WinForms/WPF thumbnail viewer.
    • Increased the performance of image drawing if Skia is used as drawing engine.
  • .NET development
    • Improved the support for transparency mask for color spaces.
  • .NET development
    • Fixed the bug in algorithm that renders Bubble chart.
    • Fixed the bug in algorithm that calculates arguments for XLSX formula.
Version 12.4.4.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that converts PDF document to a DOCX document.
    • Fixed the bugs in the spreadsheet visual editor.
  • Web development
    • Added the ability to set the layout settings for Office document in web document viewer.
  • .NET development
    • Added DicomImageVoiLutCenterDirection and DicomImageVoiLutWidthDirection properties to the DicomViewerTool/WpfDicomViewerTool visual tool.
Version 12.4.5.1 of VintaSoft Imaging .NET SDK has been released.
What's new in this version of VintaSoft Image .NET SDK:
  • .NET development
    • Now JPEG decoder can decode JPEG image if JPEG image has broken ECS segment.
  • Web development
    • Fixed the bug in WebDocumentViewerJS class.
  • .NET development
    • Fixed the bug in PDF/A-1b converter.
  • .NET development
    • Fixed the bug in converter from PDF to DOCX.
Version 12.4.6.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
  • .NET development
    • Created DicomSeriesManager class that allows to group DICOM files by patient, study, series.
  • .NET development
    • Fixed the bug in PDF encoder. Previous version of PDF encoder created not optimal PDF file when CreateNewFile parameter was set to False.
Version 12.4.7.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm of TIFF decoder.
Version 12.4.8.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Added FlattenAnnotations property to the Vintasoft.Imaging.Pdf.Processing.PdfDocumentCompressorCommand class.
    • Fixed an error in parsing XMP metadata in the PDF/A verifier.
Version 12.4.9.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that decodes the rotated JPEG image encoded in Progressive mode.
  • .NET development
    • Fixed the bug in algorithm that parses structure of DICOM file.
