The new version 12.5 of VintaSoft Imaging .NET SDK and Plug-ins has been released!
What's new in VintaSoft Imaging .NET SDK 12.5:
.NET development
RAW-image codec:
Added the ability to decode images from .CR3-files (Canon), .ARW-files (Sony) and .RW2-files (Panasonic) using "libraw" library.
Improved the algorithm for decoding .NEF- and .NRW-files (Nikon).
Improved the algorithm for decoding .CR2- and .CRW-files (Canon).
Improved the algorithm for decoding .DNG-files.
Fixed several non-critical bugs.
What's new in VintaSoft DICOM .NET Plug-in 5.5:
.NET development
Added the ability to render, view and print electrocardiogram from DICOM file:
render and print electrocardiogram
view electrocardiogram in WinForms/WPF image viewer
measure and highlight electrocardiogram data in WinForms/WPF image viewer
save electrocardiogram in vector form to PDF document or SVG image.
Created the WinForms/WPF-control "DicomSeriesManagerControl" that allows to display information about DICOM series, which are sorted by patient and study.
Added the ability to change pixel data of DICOM image to the 24-bpp color image and save changed DICOM image to a new DICOM file.
Added the ability to burn annotations and measurements to DICOM image.
Significantly improved performance of algorithm that parses structure of DICOM file.
Significantly decreased memory when working with DICOM files.
Demo-applications:
Created new demo-application "ECG Viewer Demo" for WinForms and WPF. Demo-application allows to view electrocardiogram from DICOM file.
Added many improvements in demo-applications "DICOM Viewer Demo" and "DICOM MPR Viewer Demo" for WinForms and WPF.
Web development
Created JavaScript UI-control "WebDicomControlJS" that allows to view DICOM images in HTML5 web browser:
JavaScript UI control can work in all major HTML5 web browsers
User interface is compatible with personal computers, tablets and smartphones
Load existing DICOM files
View DICOM images
Display information about DICOM images, which are sorted by patient, study, series
View DICOM images in web DICOM viewer
Show DICOM metadata over image in web DICOM viewer
Browse DICOM images in web DICOM viewer using mouse
Change the window level of DICOM image in web DICOM viewer using mouse
Zoom DICOM image in web DICOM viewer using mouse
Measure objects (line, polyline, ellipse, angle, cross) on DICOM image in web DICOM viewer using mouse
"Standard" dialogs (view DICOM metadata, ...) for Bootstrap and JQuery UI
User interface can be customized
User interface is available in 45 languages and can be easily translated into any language
Created JavaScript UI-control "WebDicomSeriesManagerControlJS" that allows to display information about DICOM series, which are sorted by patient and study, in HTML5 web browser.
Demo-applications:
Created new demo application "DICOM Viewer Demo" for ASP.NET Core, ASP.NET Core + Angular, ASP.NET MVC5, ASP.NET WebForms. Demo-application allows to view DICOM images in ASP.NET.
What's new in VintaSoft Office .NET Plug-in 4.5:
.NET development
Added the support for new chart types: Radar, 3D Pie, Surface.
Now PDF-to-DOCX converter can determine header and footer sections on PDF page and create appropriate sections in the converted DOCX document.
Added many improvements in algorithm that renders Excel chart.
Fixed many minor bugs.
What's new in VintaSoft Document Cleanup .NET Plug-in 7.5:
.NET development
Added new image processing command - DottedLineRemovalCommand, which allows to remove the horizontal dotted lines from an image.
What's new in VintaSoft OCR .NET Plug-in 7.5:
.NET development
Added the ability to recognize a line of handwritten digits using neural network based on Microsoft.ML.
Fixed minor bugs.
What's new in VintaSoft Forms Processing .NET Plug-in 5.5:
.NET development
Now OCR-fields can contain a line of handwritten digits, which is recognized using the neural network based on Microsoft.ML.
Demo-applications
Now "Forms Processing Demo" demo application allows to recognize handwritten digits in OCR-field of filled form.
Version 12.5.1.1 of VintaSoft Imaging .NET SDK has been released.
Web development
Fixed the bug in algorithm that converts DOCX/XLSX document to a raster image.
Fixed minor bugs.
Web development
Added the indication of used mouse button on UI-buttons that enables/disables the visual tool in JavaScript UI-control "WebDicomControlJS".
Added the usage of different mouse cursors for interactive points while editing a measurement object in JavaScript UI-control "WebDicomViewerControlJS".
Improved the performance of visual tool "Browse" in JavaScript UI-control "WebDicomViewerControlJS".
Version 12.5.3.1 of VintaSoft Imaging .NET SDK has been released.
Web development
Added the ability to limit the building/transformation of annotation in specified region on image in web annotation viewer (properties RaiseAnnotationEventsInViewMode and RaiseAnnotationEventsInAuthorMode in WebAnnotationVisualToolJS class).
Added the ability to raise annotation events in the Author interaction mode in web annotation viewer (properties IsAnnotationBoundingRectEnabled and AnnotationBoundingRect in WebAnnotationVisualToolJS class).
.NET development
Fixed the memory leak in DicomViewer control (WinForms and WPF).
Fixed the bug in WpfDicomSeriesManagerControl control.
Demo applications:
DicomViewerDemo/WpfDicomViewerDemo: Added the ability to drag-and-drop folders with DICOM files or DICOM files to the DICOM viewer or DICOM Series Manager.
DicomViewerDemo/WpfDicomViewerDemo: Added the ability to save DICOM image with burned annotations to the source DICOM file.
.NET development
Fixed the bug in algorithm that decodes a JPEG image data, which are stored in CalGray color space.
.NET development
Improved the algorithm that renders XLSX document.
Version 12.5.4.1 of VintaSoft Imaging .NET SDK has been released.
Web development
Fixed the bug in algorithm that updates images in web image viewer.
.NET development
Added the AutoFontMinSize and AutoFontMaxSize properties to the TextAnnotationData and WpfTextAnnotationData class.
Web development
Added the AutoFontMinSize and AutoFontMaxSize properties to the WebTextAnnotationViewJS class.
.NET development
Now PDF MRC encoder creates MRC layers in PDF layers (Vintasoft.Imaging.Codecs.Encoders.PdfMrcCompressionSettings.AddPdfLayers property) - this allows to show/hide MRC layers using PDF layers.
Improved the default PDF MRC compression settings.
Improved the algorithm that parses OpenType font program.
