Version 14.1 of VintaSoft Imaging .NET SDK has been released.
The new version 14.1 of VintaSoft Imaging .NET SDK and Plug-ins has been released!
What's new in VintaSoft Imaging .NET SDK 14.1:
  • .NET development
    • Now Vintasoft.Imaging.Drawing.SkiaSharp assembly uses SkiaSharp 3.116.1.
    • Image codecs
      • Created the decoder for SVG files.
      • Created the decoder and encoder for PSD files.
      • EMF decoder converted from raster to the vector decoder.
    • Fixed several minor bugs.
What's new in VintaSoft PDF .NET Plug-in 11.1:
  • .NET development
    • Fixed several minor bugs in font parsers.
  • Web development
    • Added the ability to edit text content of PDF document in web browser using JavaScript UI-control WebPdfDocumentEditorControlJS:
      • Split text content of PDF page into text blocks
      • Add new text block to a PDF page
      • Copy/paste text block on PDF page
      • Delete text block from PDF page
      • Change text in text block
      • Change style (font name, font size, bold, italic, underline, strikethrough, horizontal text alignment, text color) for text in text block
      • Undo/redo changes in text content on PDF page
    • Demo-applications:
      • Now web demo-application "PDF Editor Demo" allows to edit text content on PDF page.
What's new in VintaSoft Office .NET Plug-in 6.1:
  • .NET development
    • Added the ability to convert DOCX document to a HTML document.
    • Added the ability to convert ODT (OpenOffice Text) document to a DOCX document.
    • Added the ability to convert ODS (OpenOffice Spreadsheet) document to a XLSX document.
    • Improved the algorithm that converts HTML document to a DOCX document.
    • Improved the algorithm that converts RTF document to a DOCX document.
What's new in VintaSoft Annotation .NET Plug-in 14.1:
  • .NET development
    • Created Ink-annotation that displays a freehand lines composed of one or more disjoint paths.
    • Added the ability to erase annotations on image in image viewer.
    • Added the ability to erase points of line-based annotations on image in image viewer.
    • Added the ability to annotate JPEG2000 image.
    • Added the ability to use SVG-image in Image-annotation.
  • Web development
What's new in VintaSoft Forms Processing .NET Plug-in 6.1:
  • .NET development
    • Added the ability to recognize templates of OMR-marks in template of document form.
      • Now demo-application "Form Processing Demo" allows to recognize templates of OMR-marks in template of document form.
What's new in VintaSoft JPEG2000 .NET Plug-in 10.1:
  • .NET development
    • Added the ability to decode JPEG2000 image in CIELab color space.
    • Added the ability to decode JPEG2000 image in YPbPr color space.
Version 14.1.1.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Now the OpenXmlDocumentConverter class can convert ZIP archive with HTML document to a DOCX document.
    • Created the HtmlEncoder class that allows to convert DOCX document to a HTML document.
    • Improved the algorithm that converts XLS document to a XLSX document.
  • Web development
    • Demo application "ASP.NET Core File Converter Demo" now can convert DOCX document to a HTML document and vice versa.
  • .NET development
    • Fixed the bug in algorithm that renders PDF content.
Version 14.1.2.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that draws image with transparency mask on PDF page.
    • Fixed the bug in algorithm that searches "Arial Unicode MS" font for PDF document.
  • Web development
    • Fixed the bug in WebPdfDocumentEditorControlJS class.
Version 14.1.3.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that works with graphics paths using SKIA drawing engine.
Version 14.1.4.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that removes text from PDF content.
Version 14.1.5.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that parses EXIF-data in JPEG file.
  • .NET development
    • Improved the algorithm that loads ICC-profile for image-resource.
Version 14.1.6.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algoritm of TIFF encoder.
  • Web development
    • Now the WebZoomToolJS class allows to zoom of images in web image viewer using pinch zoom gesture on touch screen.
    • Now the the WebPanToolJS class can work together with WebZoomToolJS class on touch screen, i.e. one visual tool can pan (single touch) and zoom (multi touch) images in image viewer on touch screen.
Version 14.1.7.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • Improved the work of visual tools in web image viewer when web image viewer is used on touch screen.
  • .NET development
    • Improved the algorithm that handles broken Type1 font.
    • Fixed the bug in algorithm that works with fonts when converting a DOCX document to a PDF document.
Version 14.1.8.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • Improved UI of web demo application "Barcode Advanced Demo" for compatibility with touch screen.
  • .NET development
    • Fixed the bug in algorithm that layouts content of DOCX document.
    • Fixed the bug in algorithm that converts DOCX document to a PDF document.
What's new in this version of VintaSoft Forms Processing .NET Plug-in:
  • .NET development
    • Added improvements in UI of demo application "Forms Processing Demo".
Version 14.1.9.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the memory and resources leak in DocxDocumentEditor.Export method.
