Up to this point, my client is using the software to scan single membership cards and everything works fine. Now they want to scan multiple page documents and put the multi page document into one pdf file. How do I set up my code for this so that I capture multiple pages before saving the image. Here is my present code.
vsTwain1.StartDevice();
vsTwain1.ShowUI = false;
if (vsTwain1.SelectSource())
vsTwain1.DisableAfterAcquire = true;
vsTwain1.MaxImages = 1;
vsTwain1.AutoCleanBuffer = true;
vsTwain1.OpenDataSource();
vsTwain1.PixelType = PixelType.BW;
if (vsTwain1.FeederPresent)
vsTwain1.FeederEnabled = true;
vsTwain1.AutoFeed = true;
vsTwain1.XferCount = 1;
vsTwain1.PdfMultiPage = false;
if (vsTwain1.FeederLoaded)
vsTwain1.ShowIndicators = true;
if (vsTwain1.AcquireModal())
this.Cursor = Cursors.WaitCursor;
MemoryStream mem = new MemoryStream();
mem = vsTwain1.GetImageAsStream(0, ImageFileFormat.PDF);
string dirPath = "\\\\192.168.254.5\\RelatedDocuments\\EmployerDocuments\\" + myController.CurrentEmployer.Office + "\\";
string dateString = DateTime.Now.Year.ToString() + DateTime.Now.Month.ToString("00") + DateTime.Now.Day.ToString("00");
string filePath = myController.CurrentEmployer.EmployerId + dateString + ".pdf";
myController.SaveScannedRecord(Int32.Parse(ScanItemTypeComboBox.SelectedValue.ToString()), filePath);
vsTwain1.SaveImage(0, dirPath + filePath);
catch (TwainException ex)
MessageBox.Show(ex.Message);
vsTwain1.StopDevice();
MessageBox.Show("Scan completed.");
Scanning multiple pages
Re: Scanning multiple pages
Hello Bill,
Your code has logical mistake - you should use "while" statement instead of the "if" when you work with AcquireModal method. Here is correct code:
//if (vsTwain1.AcquireModal()) - wrong code
while (vsTwain1.AcquireModal()) - correct code
BillG
Do I need to set the MaxImages property to the number of pages being scanned?
Yes, you should set the MaxImages property if you want to store pages in the internal buffer of the library but make sure that you have enough memory. The best way is to store images in the MemoryStream or file.Do I need to set the MaxImages property to the number of pages being scanned?
BillG
How do I change the above change to scan multiple pages and save them in the same pdf file?
BillG
I tried this but got a attempted to divide by zero error
vsTwain1.MaxImages = Int32.Parse(NumberOfPagesTextBox.Value.ToString());
int pageCount = 0;
mem = vsTwain1.GetImageAsStream(pageCount, ImageFileFormat.PDF);
pageCount++;
if (vsTwain1.ErrorCode != Vintasoft.Twain.ErrorCode.None)
MessageBox.Show(vsTwain1.ErrorString);
string dirPath = "q:\\JobSiteDocuments\\" + myController.CurrentJobSite.Office + "\\";
RelatedDocumentType rdType = (RelatedDocumentType)ScanItemTypeComboBox.SelectedItem;
string docDesc = rdType.DocumentTypeDesc;
string filePath = myController.CurrentJobSite.JobSiteId + docDesc + dateString + ".pdf";
Int32 numOfPages = Int32.Parse(NumberOfPagesTextBox.Value.ToString());
myController.SaveScannedRecord(Int32.Parse(rdType.DocumentTypeId.ToString()), filePath, DescriptionTextBox.Text.ToString(), numOfPages);
DescriptionTextBox.Text = string.Empty;
NumberOfPagesTextBox.Value = 1;
PopulateDocumentsGrid();
this.Cursor = Cursors.Arrow;
int pageCount = 0;
pageCount++;
BillG
Well I have it now scanning multiple pages and creating only one pdf file but it always only saves the last page.
bool firstImage = true;
int counter = 0;
if (firstImage)
firstImage = false;
counter++;
vsTwain1.SaveImageToStream(counter, mem, ImageFileFormat.PDF);
counter++;
vsTwain1.SaveImage(vsTwain1.MaxImages-1, dirPath + filePath);
int counter = 0;
if (firstImage)
firstImage = false;
counter++;
counter++;
Hello Bill,
Please read this topic:
viewtopic.php?f=19&t=3
What scanner do you have? Maybe Brother?Well I have it now scanning multiple pages and creating only one pdf file but it always only saves the last page.
