What is TWAIN and WIA driver?
bharate.umesh
Post by bharate.umesh »
What is the difference between TWAIN and WIA driver?
I have Kodak Scanmate i1120 scanner.
When I run the application, it shows two scanner sources.
1) KODAK Scanner: i1120
2) WIA-KODAK i1120 Scanner
Which source should I select?
Thanks,Umesh
Re: What is TWAIN and WIA driver?
Hello Umesh,
You should select "KODAK Scanner: i1120" because WIA drivers are not fully compatible with TWAIN specification.
bharate.umesh
Thnx Alex
