I'd like to get the already generated data for the thumbnail image in the thumbnailviewer.
With GetThumbnailImage the viewer is generating a new on.
How I can get this reference?
(On the event ThumbnailPainting there is e.Thumbnail ... this is what i want to have, but directly from imagecollection)
Thomas
get a reference to the thumbnail image
Re: get a reference to the thumbnail image
Hello Thomas,
What do you want to do? Maybe you want to generate thumbnail with custom appearance?
Thomas
With the help of the thumbnailviewer we edit and arrange some (or more
)images. In parallel we generate a preview for the resulting output. In this preview we want to use the already generated thumbnail (to save some time, because this process was time critical). So I will give a handle to the image(s) to the preview.
Thomas
do you need more info?
Regards Thomas
Regards Thomas
Hello Thomas,
Please see our Thumbnail Viewers Demo here: http://www.vintasoft.com/vsimaging-dotnet-examples.html
and read description of the Vintasoft.Imaging.ThumbnailViewer.ThumbnailPainting event in the documentation - I think these information will help you.
Thomas
Hello Alexander,
no, this will not help me. This event is only fired when the image is 'in view'.
What I want to do:
- Load some images into the thumbnailviewer
- Let the user do some work with the images (change the order, select and unselect ...)
- Next step: show a preview of the result. Here I want to loop through the images of the thumbnailviewer and get the already generated thumbnailimage from the thumbnailviewer. Not the hole image (it is too large) and not a new thumbnailimage with getthumbnailimage (this take too long to generate).
Is this possible?
Thomas
What I want to do:
Is this possible?
Thomas
Hello Thomas,
I have understood your problem - we will add ability to get thumbnails from ThumbnailViewer in version 4.1 of VintaSoftImaging.NET Library, I think in 2 months.
Thomas
Hello Alexander,
thanks for adding this functionality. Until 4.1 I will do a workaround and generate a second thumbnail while adding an image.
Thomas
Thomas
