Reading Exif/GPS data from loaded image
You need to import necessary namespaces:
js95007
Post by js95007 »
Thanks for that, however I included:
though all three come up with warnings, "Namespace or type specified in the Imports 'Vintasoft.Imaging.Codecs.Tiff' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases."
Any suggestions?
Have you added reference to Vintasoft.Imaging.dll from your project?
If yes, please send your project for tests to support@vintasoft.com
js95007
Post by js95007 »
Where would I be able to download that from
Please download VintaSoftImaging.NET SDK from our web site.
js95007
Post by js95007 »
Hey I have downloaded the SDK, referenced the Vintasoft.Imaging.dll into Visual Basic, however:
The line
code]Using jpegStream As FileStream = New FileStream("..\..\geotag005.jpg", FileMode.Open, FileAccess.Read)[[/code]
Shows up as an error, being undefined, with the option to add "Import System.io
So I did that, which removed that particular error, but now:
Dim exif As ExifData = jpeg.Exif
shows up as an error, Error --- "Vintasoft.Imaging.Codecs.Jpeg.JpegFile"
Please send me full description of error.
Since version 5.0.3 the JpegFile.Exif property was moved to JpegPage.Exif.
You should use this code:
I have updated code of all examples in this topic.
js95007
Post by js95007 »
Thanks works much better :D
However is there any way to make this into readable, standard GPS long/lat format? Currently if I copy everything into Microsoft Word, there are 12 pages of assorted statements and numbers.
