Twain VS WinTwain
Fastrx
Twain VS WinTwain
Twain SDK has 2 Namespaces: Twain and WinTwain. I wonder what is the difference between the two, and which one to use.
Re: Twain VS WinTwain
Vintasoft.Twain.dll - .NET assembly that can be used in .NET application for Windows and Linux. This assembly uses drawing primitives from Vintasoft.Shared library.
Vintasoft.WinTwain.dll - .NET assembly that can be used in .NET application for Windows. This assembly uses drawing primitives from System.Drawing.Common library.
Vintasoft.WpfTwain.dll - .NET assembly that can be used in WPF application for Windows. This assembly uses drawing primitives from WPF library.
This information is available here: https://www.vintasoft.com/docs/vstwain- ... v14_0.html
You need to use Vintasoft.Twain.dll, Vintasoft.WinTwain.dll or Vintasoft.WpfTwain.dll depending from your application and your task.
Vintasoft.Twain namespace is present in Vintasoft.Twain.dll assembly. Vintasoft.WinTwain namespace is present in Vintasoft.WinTwain.dll assembly.Twain SDK has 2 Namespaces: Twain and WinTwain. I wonder what is the difference between the two, and which one to use.
