Version 15.0 of VintaSoft Imaging .NET SDK has been released.
The new version 15.0 of VintaSoft Imaging .NET SDK and Plug-ins has been released!
What's new in VintaSoft Imaging .NET SDK 15.0:
  • .NET development
    • Added support for .NET 10 in Windows, Linux and macOS.
  • Web development
    • Added the WebUiUndoRedoToolbarPanelJS panel that allows to enable/disable the undo history, navigate the undo history, view an action list in undo history.
    • Demo applications
      • Added the ability to use undo history for image processing operations in web demo application "Imaging Demo".
What's new in VintaSoft Office .NET Plug-in 7.0:
  • .NET development
    • The Plug-in edition "Spreadsheet" has been replaced by the Plug-in edition "Visual Editor" and now includes UI-controls for visual editing of DOCX and XLSX documents.
    • Created the WinForms-control DocumentEditor and WPF-control WpfDocumentEditor, which allow to edit DOCX document in WinForms/WPF application:
      • Create a new or open an existing DOCX document in WinForms/WPF document editor
      • Display and print document
      • Add/change/delete text content in document
      • Change text properties (font, font size, bold, italic, text color, ...) in a document
      • Change paragraph properties (style, text alignment, text indent, list style, ...) in a document
      • Insert/delete page break
      • Add/edit/delete header or footer
      • Change page settings
      • Change settings of page columns
      • Save changes in DOCX document
      • Export DOCX document to a PDF format
    • Added many fixes to decoder of DOCX document.
    • Added many fixes to decoder of XLSX document.
    • Demo applications:
      • Created the demo application "Document Editor Demo", which demonstrates how to edit DOCX document in WinForms application
      • Created the demo application "WPF Document Editor Demo", which demonstrates how to edit DOCX document in WPF application
    • Here is screenshot of VintaSoft WinForms Document Editor Demo: Image
  • Web development
    • Created the JavaScript UI-control WebDocumentEditorJS, which allows to edit DOCX document in web application:
      • Create a new or open an existing DOCX document in web document editor
    • Demo applications
      • Created the demo application "ASP.NET Core Document Editor Demo", which demonstrates how to edit DOCX document in ASP.NET Core application
      • Created the demo application "ASP.NET Core Angular Document Editor Demo", which demonstrates how to edit DOCX document in "Angular + ASP.NET Core" application
      • Created the demo application "ASP.NET MVC Document Editor Demo", which demonstrates how to edit DOCX document in ASP.NET MVC5 application
      • Created the demo application "ASP.NET Document Editor Demo", which demonstrates how to edit DOCX document in ASP.NET WebForms application
    • Here is screenshot of VintaSoft ASP.NET Core Document Editor Demo: Image
What's new in VintaSoft PDF .NET Plug-in 12.0:
  • .NET development
What's new in VintaSoft DICOM .NET Plug-in 8.0:
  • .NET development
    • Added the ability to create a perpendicular multi slice for a curved DICOM slice.
What's new in VintaSoft OCR .NET Plug-in 9.0:
  • .NET development
    • Added support for .NET 10 in Windows and Linux.
    • The used Tesseract OCR engine has been updated to version 5.5.1.
What's new in VintaSoft Annotation .NET Plug-in 15.0:
  • .NET development
  • Web development
    • Demo applications
      • Added the ability to display and navigate the undo history for annotations in web demo application "Annotation Demo".
What's new in VintaSoft JBIG2 .NET Plug-in 12.0:
  • .NET development
What's new in VintaSoft JPEG2000 .NET Plug-in 11.0:
  • .NET development
What's new in VintaSoft Document Cleanup .NET Plug-in 9.0:
  • .NET development
What's new in VintaSoft Forms Processing .NET Plug-in 7.0:
  • .NET development
Version 15.0.1.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • Fixed the bug in algorithm that extracts text from document.
  • .NET development
    • Improved the algorithm that selects optimal PDF compression in the "Auto" mode.
    • Fixed the bug in algorithm that copies metadata when PDF document is saving to another PDF document.
    • Fixed the bug in PDF MRC compressor.
    • Fixed the bug in the RemoveTransparencyFromContentStreamCommand class.
  • Web development
    • Added improvements in JavaScript UI-control WebPdfDocumentEditorJS.
  • .NET development
    • Added improvements in WinForms UI-control DocumentEditor.
    • Added improvements in WPF UI-control WpfDocumentEditor.
    • Fixed several bugs in WinForms UI-control DocumentEditor.
    • Fixed several bugs in WPF UI-control WpfDocumentEditor.
  • Web development
    • Added improvements in JavaScript UI-control WebDocumentEditorJS.
    • Fixed several bugs in JavaScript UI-control WebDocumentEditorJS.
  • .NET development
    • Added new interaction mode "ViewProcessing" that allows to apply an image processing command to a rectangular region in DICOM viewer (WinForms, WPF).
      • Added the ability to apply an image processing command to a rectangular region in DICOM viewer and DICOM MPR viewer (WinForms, WPF).
Version 15.0.2.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • The WinForms/WPF UI-control DocumentEditor now allows to select the document interaction mode: editing or viewing.
    • Fixed several bugs in WinForms/WPF UI-control DocumentEditor.
      • The WinForms/WPF demo application "DocumentEditorDemo" now allows you to convert file in PDF, RTF, DOC, ODT, HTML, TXT format to a DOCX file and open the converted DOCX file for viewing and editing.
  • Web development
    • The JavaScript UI-control WebDocumentEditorJS now allows to select the document interaction mode: editing or viewing.
      • The web demo application "DocumentEditorDemo" now allows you to convert file in PDF, RTF, DOC, ODT format to a DOCX file and open the converted DOCX file for viewing and editing.
  • .NET development
    • Fixed the bug in algorithm that displays measurement annotations on DICOM image in DICOM viewer.
      • Added the ability to apply an image processing command to the entire image in DICOM viewer and DICOM MPR viewer (WinForms, WPF).
  • .NET development
    • Fixed the bug in algorithm that renders PDF page in image viewer. The error occurred if the PDF page size exceeded 250 megapixels.
  • .NET development
    • Fixed the bug in DespeckleCommand class.
Version 15.0.3.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that renders PDF image-resources, which are compressed with CCITT compression, in the evaluation version for .NET Core.
    • Fixed the bug in PdfDrawingEngine class in algorithm that processes clip regions in PDF content. This bug affected the PdfSimplifyContentCommand class.
  • .NET development
      • The demo applications "DicomMprViewerDemo" and "WpfDicomMprViewerDemo" now allows to export/import the measurement annotations.
Version 15.0.4.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • The WebPrintManagerJS class now allows to print several images/pages on 1 printer page.
    • The UI-dialog WebPrintImagesDialogJS now allows to print several images/pages on 1 printer page.
  • .NET development
    • The UI-controls DocumentEditor and WpfDocumentEditor now allow to use an interactive ruler, which allows you to visually change page indents, paragraph indents, and section column settings, in document editor mode.
    • Fixed several bugs in UI-controls DocumentEditor and WpfDocumentEditor.
  • Web development
    • The UI-control WebDocumentEditorJS now allows to use an interactive ruler, which allows you to visually change page indents, paragraph indents, and section column settings, in document editor mode.
    • The UI-dialog WebUiPrintDocxDocumentSettingsDialogJS now allows to print several images/pages on 1 printer page.
    • Fixed several bugs in UI-control WebDocumentEditorJS.
Version 15.0.5.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that extracts text from document page.
