Version 15.0 of VintaSoft Imaging .NET SDK has been released.
The new version 15.0 of VintaSoft Imaging .NET SDK and Plug-ins has been released!
What's new in VintaSoft Imaging .NET SDK 15.0:
  • .NET development
    • Added support for .NET 10 in Windows, Linux and macOS.
  • Web development
    • Added the WebUiUndoRedoToolbarPanelJS panel that allows to enable/disable the undo history, navigate the undo history, view an action list in undo history.
    • Demo applications
      • Added the ability to use undo history for image processing operations in web demo application "Imaging Demo".
What's new in VintaSoft Office .NET Plug-in 7.0:
  • .NET development
    • The Plug-in edition "Spreadsheet" has been replaced by the Plug-in edition "Visual Editor" and now includes UI-controls for visual editing of DOCX and XLSX documents.
    • Created the WinForms-control DocumentEditor and WPF-control WpfDocumentEditor, which allow to edit DOCX document in WinForms/WPF application:
      • Create a new or open an existing DOCX document in WinForms/WPF document editor
      • Display and print document
      • Add/change/delete text content in document
      • Change text properties (font, font size, bold, italic, text color, ...) in a document
      • Change paragraph properties (style, text alignment, text indent, list style, ...) in a document
      • Insert/delete page break
      • Add/edit/delete header or footer
      • Change page settings
      • Change settings of page columns
      • Save changes in DOCX document
      • Export DOCX document to a PDF format
    • Added many fixes to decoder of DOCX document.
    • Added many fixes to decoder of XLSX document.
    • Demo applications:
      • Created the demo application "Document Editor Demo", which demonstrates how to edit DOCX document in WinForms application
      • Created the demo application "WPF Document Editor Demo", which demonstrates how to edit DOCX document in WPF application
    • Here is screenshot of VintaSoft WinForms Document Editor Demo: Image
  • Web development
    • Created the JavaScript UI-control WebDocumentEditorJS, which allows to edit DOCX document in web application:
      • Create a new or open an existing DOCX document in web document editor
    • Demo applications
      • Created the demo application "ASP.NET Core Document Editor Demo", which demonstrates how to edit DOCX document in ASP.NET Core application
      • Created the demo application "ASP.NET Core Angular Document Editor Demo", which demonstrates how to edit DOCX document in "Angular + ASP.NET Core" application
      • Created the demo application "ASP.NET MVC Document Editor Demo", which demonstrates how to edit DOCX document in ASP.NET MVC5 application
      • Created the demo application "ASP.NET Document Editor Demo", which demonstrates how to edit DOCX document in ASP.NET WebForms application
    • Here is screenshot of VintaSoft ASP.NET Core Document Editor Demo: Image
What's new in VintaSoft PDF .NET Plug-in 12.0:
  • .NET development
What's new in VintaSoft DICOM .NET Plug-in 8.0:
  • .NET development
    • Added the ability to create a perpendicular multi slice for a curved DICOM slice.
What's new in VintaSoft OCR .NET Plug-in 9.0:
  • .NET development
    • Added support for .NET 10 in Windows and Linux.
    • The used Tesseract OCR engine has been updated to version 5.5.1.
What's new in VintaSoft Annotation .NET Plug-in 15.0:
  • .NET development
  • Web development
    • Demo applications
      • Added the ability to display and navigate the undo history for annotations in web demo application "Annotation Demo".
What's new in VintaSoft JBIG2 .NET Plug-in 12.0:
  • .NET development
What's new in VintaSoft JPEG2000 .NET Plug-in 11.0:
  • .NET development
What's new in VintaSoft Document Cleanup .NET Plug-in 9.0:
  • .NET development
What's new in VintaSoft Forms Processing .NET Plug-in 7.0:
  • .NET development
Version 15.0.1.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • Fixed the bug in algorithm that extracts text from document.
  • .NET development
    • Improved the algorithm that selects optimal PDF compression in the "Auto" mode.
    • Fixed the bug in algorithm that copies metadata when PDF document is saving to another PDF document.
    • Fixed the bug in PDF MRC compressor.
    • Fixed the bug in the RemoveTransparencyFromContentStreamCommand class.
  • Web development
    • Added improvements in JavaScript UI-control WebPdfDocumentEditorJS.
  • .NET development
    • Added improvements in WinForms UI-control DocumentEditor.
    • Added improvements in WPF UI-control WpfDocumentEditor.
    • Fixed several bugs in WinForms UI-control DocumentEditor.
    • Fixed several bugs in WPF UI-control WpfDocumentEditor.
  • Web development
    • Added improvements in JavaScript UI-control WebDocumentEditorJS.
    • Fixed several bugs in JavaScript UI-control WebDocumentEditorJS.
  • .NET development
    • Added new interaction mode "ViewProcessing" that allows to apply an image processing command to a rectangular region in DICOM viewer (WinForms, WPF).
      • Added the ability to apply an image processing command to a rectangular region in DICOM viewer and DICOM MPR viewer (WinForms, WPF).
Version 15.0.2.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • The WinForms/WPF UI-control DocumentEditor now allows to select the document interaction mode: editing or viewing.
    • Fixed several bugs in WinForms/WPF UI-control DocumentEditor.
      • The WinForms/WPF demo application "DocumentEditorDemo" now allows you to convert file in PDF, RTF, DOC, ODT, HTML, TXT format to a DOCX file and open the converted DOCX file for viewing and editing.
  • Web development
    • The JavaScript UI-control WebDocumentEditorJS now allows to select the document interaction mode: editing or viewing.
      • The web demo application "DocumentEditorDemo" now allows you to convert file in PDF, RTF, DOC, ODT format to a DOCX file and open the converted DOCX file for viewing and editing.
  • .NET development
    • Fixed the bug in algorithm that displays measurement annotations on DICOM image in DICOM viewer.
      • Added the ability to apply an image processing command to the entire image in DICOM viewer and DICOM MPR viewer (WinForms, WPF).
  • .NET development
    • Fixed the bug in algorithm that renders PDF page in image viewer. The error occurred if the PDF page size exceeded 250 megapixels.
  • .NET development
    • Fixed the bug in DespeckleCommand class.
Version 15.0.3.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that renders PDF image-resources, which are compressed with CCITT compression, in the evaluation version for .NET Core.
    • Fixed the bug in PdfDrawingEngine class in algorithm that processes clip regions in PDF content. This bug affected the PdfSimplifyContentCommand class.
  • .NET development
      • The demo applications "DicomMprViewerDemo" and "WpfDicomMprViewerDemo" now allows to export/import the measurement annotations.
Version 15.0.4.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • The WebPrintManagerJS class now allows to print several images/pages on 1 printer page.
    • The UI-dialog WebPrintImagesDialogJS now allows to print several images/pages on 1 printer page.
  • .NET development
    • The UI-controls DocumentEditor and WpfDocumentEditor now allow to use an interactive ruler, which allows you to visually change page indents, paragraph indents, and section column settings, in document editor mode.
    • Fixed several bugs in UI-controls DocumentEditor and WpfDocumentEditor.
  • Web development
    • The UI-control WebDocumentEditorJS now allows to use an interactive ruler, which allows you to visually change page indents, paragraph indents, and section column settings, in document editor mode.
    • The UI-dialog WebUiPrintDocxDocumentSettingsDialogJS now allows to print several images/pages on 1 printer page.
    • Fixed several bugs in UI-control WebDocumentEditorJS.
Version 15.0.5.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that extracts text from document page.
Version 15.0.6.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Now the point object builder (PointBasedObjectPointBuilder and WpfPointBasedObjectPointBuilder classes) allows to finish the object's build by pressing the right mouse button and allows to delete the last point of the object by pressing the middle mouse button.
  • .NET development
    • Now UI-controls DocumentEditor and WpfDocumentEditor allow to add/transform/edit/delete image on document page.
    • Now UI-controls DocumentEditor and WpfDocumentEditor allow to add/transform/edit/delete graphic objects on document page.
    • Now UI-controls DocumentEditor and WpfDocumentEditor open dialog for editing of paragraph/page/section settings when mouse is double clicked on the ruler slider.
    • Now UI-controls DocumentEditor and WpfDocumentEditor provide better performance when rendering document with images.
      • DocumentEditorDemo/WpfDocumentEditorDemo: Added the ability to add/transform/edit/delete an image or graphic object on a document page.
  • Web development
    • Now JavaScript UI-control WebDocumentEditorJS allows to add/transform/edit/delete image on document page.
    • Now JavaScript UI-control WebDocumentEditorJS allows to add/transform/edit/delete graphic objects on document page.
    • Now JavaScript UI-control WebDocumentEditorJS opens dialog for editing of paragraph/page/section settings when mouse is double clicked on the ruler slider.
    • Now JavaScript UI-control WebDocumentEditorJS provides better performance when rendering document with images.
      • WebDocumentEditorDemo: Added the ability to add/transform/delete an image or graphic object on a document page.
  • .NET development
    • Fixed the bug in algorithm that adds Bengali text to a PDF page.
  • .NET development
      • WpfDicomMprViewerDemo: Fixed the bug in algorithm that builds a curvilinear DICOM slice.
