Problems with scanning and distortion
BillG
When scanning a document by manually pressing scanner buttons, document scans perfectly. When using the library, and programmatically scanning the document, the document appears distorted. This is on an hp N6010 scanjet.
BillG
Re: Problems with scanning and distortion
I should add that in the pdf format it appears slanted to the left.
BillG
Well I switched and used the WIA driver instead of the twain and that seemed to solve the problem.
Hello Bill,
Please generate a log-file and send it to our support team at support@vintasoft.com. Also we need distorted and good image. Thank you in advance.
