Problems with scanning and distortion
When scanning a document by manually pressing scanner buttons, document scans perfectly. When using the library, and programmatically scanning the document, the document appears distorted. This is on an hp N6010 scanjet.
Re: Problems with scanning and distortion
I should add that in the pdf format it appears slanted to the left.
Well I switched and used the WIA driver instead of the twain and that seemed to solve the problem.
Hello Bill,
Please generate a log-file and send it to our support team at support@vintasoft.com. Also we need distorted and good image. Thank you in advance.
