add bookmark in annotion viewer
GHWels
Post by GHWels »
Hello
Is it possible to add bookmarks to image?
thank you
Re: add bookmark in annotion viewer
You can add annotation to an image. A list of supported annotations can be found here: http://www.vintasoft.com/docs/vsimaging ... _Data.html
GHWels
Post by GHWels »
Hello Alex!
Sorry my question was not exact.
I added annotions to an image or PDF. (that works)
I want to add PDF-bookmarks in the annotion- or image-viewer and save it as PDF.
Best regards GHWels
Hello Gunther,
Please do the following steps:
  • Run our PDF Editor Demo v8.4
  • Open multipage PDF document
  • Select the "Annotations / Form Fields" tab
  • Select the Edit mode in the "Interaction Mode" group
  • Select "Link" annotation on the "Annotations" tab and add annotation to a PDF page, the "Create Action" dialog will appear
  • Select "Goto Action" in the "Create Action" dialog, click "Ok" button - the "Goto Action Editor" dialog will appear
  • Select the necessary page index and position in the "Goto Action Editor" dialog, click "Ok" button - Link annotation will appear on PDF page
  • Select the Markup mode in the "Interaction Mode" group
  • Click on Link annotation on PDF page and you will be navigated to another PDF page
  • Save changes in PDF document if necessary
Is this functionality suitable for your needs?
