Customize toolbar options
Johnsnow
Post by Johnsnow »
I am trying this demo.
https://demos.vintasoft.com/AspNetMvcAnnotationDemo/
As there are separate tabs for toolbar options (File, View, Tools, Annotations) and all tabs has different options, Is there any way to display all options from all these tabs as single toolbar strip.
Thanks.
Re: Customize toolbar options
Hi John,
Yes, it is possible to customize menu (toolbar) of VintaSoft web document viewer.
Here is JavaScript code snippet from VintaSoft ASP.NET Annotation Demo that demonstrates how menu is created:
 Initializes main menu of document viewer.
 @param {object} docViewerSettings Settings of document viewer.
function __initMenu(docViewerSettings) {
    // get items of document viewer
    var items = docViewerSettings.get_Items();
    var uploadFileButton = items.getItemByRegisteredId("uploadFileButton");
    if (uploadFileButton != null)
        uploadFileButton.set_FileExtensionFilter(".bmp, .emf, .gif, .ico, .cur, .jpg, .jpeg, .jls, .pcx, .png, .tif, .tiff, .wmf, .jb2, .jbig2, .jp2, .j2k, .j2c, .jpc, .pdf");
    // get the main menu of document viewer
    var mainMenu = items.getItemByRegisteredId("mainMenu");
    // if main menu is found
    if (mainMenu != null) {
        // get items of main menu
        var mainMenuItems = mainMenu.get_Items();
        // add "Annotation" menu panel
        mainMenuItems.addItem("annotationsMenuPanel");
    // get the "File" menu panel
    var fileMenuPanel = items.getItemByRegisteredId("fileToolbarPanel");
    // if menu panel is found
    if (fileMenuPanel != null) {
        // get items of file menu panel
        var fileMenuPanelItems = fileMenuPanel.get_Items();
        // add the "Previous uploaded files" button to the menu panel
        fileMenuPanelItems.insertItem(1, "previousUploadFilesButton");
    // get the "View" menu panel
    var viewMenuPanel = items.getItemByRegisteredId("viewMenuPanel");
    if (viewMenuPanel != null) {
        // get items of menu panel
        var viewMenuPanelItems = viewMenuPanel.get_Items();
        // add the "Image viewer settings" button to the menu panel
        viewMenuPanelItems.insertItem(viewMenuPanelItems.get_Count() - 1, "imageViewerSettingsButton");
You can see this code in source codes of VintaSoft ASP.NET Annotation Demo in installation of VintaSoft Imaging NET SDK - function __initMenu in file "[SdkInstallPath]\VintaSoft\Imaging .NET v11.0\Examples\ASP.NET MVC\CSharp\AspNetMvcAnnotationDemo\Scripts\AnnotationDemo.js".
Also please read how to customize UI of VintaSoft web document viewer in documentation: https://www.vintasoft.com/docs/vsimagin ... er_UI.html
Johnsnow
Post by Johnsnow »
Hi Alexander,
I want to move all buttons from File, View, Tools panel to Annotations toolbar panel with separator, Can you advise for the same?
John
Hi John,
Sorry for delay.
Here is JavaScript code that demonstrates how to initialize main menu in VintaSoft web document viewer (create "Annotations" menu that contains items of "File", "View", "Tools" and "Annotations" menus):
function __initMenuInVintasoftWebDocumentViewer(docViewerSettings) {
    // get the main menu of VintaSoft web document viewer
        // add "Annotation" menu panel to the main menu
        // remove "File" menu from main menu
        mainMenuItems.removeItemAt(0);
        // remove "View" menu from main menu
        // remove "Tools" menu from main menu
        // find "Annotations" menu in main menu
        var annotationsMenu = items.getItemByRegisteredId("annotationsMenuPanel");
        // get items of "Annotations" menu
        var annotationMenuItems = annotationsMenu.get_Items();
        // insert "File" menu into "Annotations" menu
        annotationMenuItems.insertItem(0, "fileToolbarPanel");
        // insert divider into "Annotations" menu
        annotationMenuItems.insertItem(1, "vertDivider");
        // insert items of "View" menu into "Annotations" menu
        annotationMenuItems.insertItem(2, "sizeModeToggleButton");
        annotationMenuItems.insertItem(3, "rotateToolbarPanel");
        annotationMenuItems.insertItem(4, "thumbnailViewerSettingsButton");
        annotationMenuItems.insertItem(5, "vertDivider");
        // insert "Tools" menu into "Annotations" menu
        annotationMenuItems.insertItem(6, "visualToolsToolbarPanel");
        annotationMenuItems.insertItem(7, "vertDivider");
In menu you can use standard or custom UI button or UI panel.
You can get information about string identifiers of standard UI elements in documentation: https://www.vintasoft.com/docs/vsimagin ... oryJS.html
Please read how to create custom UI button here: https://www.vintasoft.com/docs/vsimagin ... utton.html
