Cannot create decoder for file.
Johnsnow
Post by Johnsnow »
When I running project on localhost and opening file in document viewer its working as expected, but when I hosted application on IIS its throwing this error "Cannot create decoder for "{Network Path}\PDF2.pdf" file."
I am using this code to initialize document viewer
// create the document viewer settings
    var docViewerSettings = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerSettingsJS("documentViewerContainer", { annotations: true });
    // initialize main menu of document viewer
    __initMenu(docViewerSettings);
    // initialize side panel of document viewer
    __initSidePanel(docViewerSettings);
    // initialize image viewer panel of document viewer
    __initImageViewerPanel(docViewerSettings);
    _docViewer = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerJS(docViewerSettings);
and this code to open file
_docViewer.openFile(filePath);
Please advise.
John
Re: Cannot create decoder for file.
Hi John,
You have the problem because VintaSoft Imaging .NET SDK cannot create decoder for PDF document because the SDK cannot find Vintasoft.Imaging.Pdf.dll assembly. For solving the problem please add reference to the Vintasoft.Imaging.Pdf.dll assembly to your ASP.NET project.
Johnsnow
Post by Johnsnow »
I had already included following dlls
Vintasoft.Barcode.AspNetCore.ApiControllers.dll
Vintasoft.Barcode.dll
Vintasoft.Barcode.Web.Services.dll
Vintasoft.Imaging.Annotation.AspNetCore.ApiControllers.dll
Vintasoft.Imaging.Annotation.dll
Vintasoft.Imaging.Annotation.Pdf.dll
Vintasoft.Imaging.Annotation.UI.dll
Vintasoft.Imaging.Annotation.Web.Services.dll
Vintasoft.Imaging.AspNetCore.ApiControllers.dll
Vintasoft.Imaging.dll
Vintasoft.Imaging.Office.OpenXml.dll
Vintasoft.Imaging.UI.dll
Vintasoft.Imaging.Web.Services.dll
Vintasoft.Shared.dll
Vintasoft.Shared.Web.dll
But getting same error "Cannot create decoder for file" in all files (jpg, png, tiff, pdf, docx etc.)
Please advise.
John
Thank you for information.
By default VintaSoft Web services use folder "UploadedImageFiles" for storing uploaded file. Also web services use folder "VintasoftCache" for storing cache files (image tiles, thumbnails, annotations, etc). Folders "UploadedImageFiles" and "VintasoftCache" must have read-write access for IIS user.
I think you have problem because you have not created folders "UploadedImageFiles"/"VintasoftCache" or you have not provided read-write access to the folders.
If you want to disable caching in web image viewer (do not store image tiles in "VintasoftCache" folder), please read how to do this in "Caching images on the server" section here: https://www.vintasoft.com/docs/vsimagin ... owser.html
If you want to disable caching in web thumbnail viewer (do not store thumbnails in "VintasoftCache" folder), please read how to do this in "Caching thumbnails on the server" section here: https://www.vintasoft.com/docs/vsimagin ... owser.html
If you do not want to store uploaded files in "UploadedImageFiles" files, you can override behavoiur of web service.
If you want to store uploaded files in database, please read how to do this here: https://www.vintasoft.com/docs/vsimagin ... abase.html
VintaSoft Imaging .NET SDK has open architecture and allows to override any behaviour of SDK.
