Posts: 2397 Joined: Thu Jul 10, 2008 2:21 pm
Post
by Alex » Fri Nov 22, 2019 10:50 am
We are proud to announce the release of new major version 9.0 of VintaSoft Imaging .NET SDK and the related Annotation, PDF,
JBIG2, JPEG2000, Document Cleanup, OCR, DICOM, Forms Processing and Office Plug-ins.
What's new in VintaSoft Imaging .NET SDK 9.0:
.NET development
Added support (without UI controls) for .NET Core 3.0 for Windows .
Created new visual tool - DocumentNavigationTool and WpfDocumentNavigationTool, which allow to navigate pages of PDF and DOCX documents in WinForms and WPF image viewer.
Created console demo applications for .NET Core and .NET Framework
Created new WinForms demo application - DocumentViewerDemo, and WPF demo application - WpfDocumentViewerDemo, which allow to extract, select and search text in documents (PDF, DOCX), annotate documents, convert DOCX documents to a PDF or PDF/A documents , print documents
Web development
Created the platform-independent .NET Core web services for rendering images/thumbnails and image processing.
Created ASP.NET Core API controllers for rendering images/thumbnails and image processing in ASP.NET Core MVC .
Created new visual tool - WebDocumentNavigationToolJS, which allows to navigate pages of PDF and DOCX documents in web image viewer.
Created the SVG icons for the web document viewer .
Created demo applications for ASP.NET Core MVC .
More info please read here: https://www.vintasoft.com/vsimaging-dotnet-history.html
What's new in VintaSoft Office .NET Plug-in 1.0:
Created VintaSoft Office .NET Plug-in - the new add-on for VintaSoft Imaging .NET SDK with the following abilities:
Supported platforms: .NET Core 3.0 for Windows, .NET Framework 4+ and 3.5
Render DOCX documents
View DOCX documents in WinForms, WPF and WEB
Print DOCX documents in vector and raster form
Convert DOCX document to a vector PDF or PDF/A document with text, links and navigation
Overlay DOCX page over PDF page in vector form and with text
Convert DOCX document to any image format supported by the SDK
Search and extract text from DOCX document
Use mouse for selecting text in DOCX document in image viewer
Use keyboard for selecting and navigating text in DOCX document in image viewer
Navigate links in DOCX document in image viewer
What's new in VintaSoft Annotation .NET Plug-in 9.0:
.NET development
Web development
Created the platform-independent .NET Core web service for annotating images and documents .
Created ASP.NET Core API controller for annotating images and documents in ASP.NET Core MVC .
Created AspNetCoreAnnotationDemo, which demonstrates how to view and annotate images and documents in ASP.NET Core MVC.
More info please read here: https://www.vintasoft.com/vsannotation- ... story.html
What's new in VintaSoft PDF .NET Plug-in 6.0:
.NET development
Added new command - PdfSimplifyContentCommand, which allows to simplify vector content of PDF file.
Decreased the memory usage in algorithm that extracts and selects text on PDF page.
Web development
Created the platform-independent .NET Core web service for working with PDF documents .
Created ASP.NET Core API controller for working with PDF documents in ASP.NET Core MVC .
Added the ability to fill out the interactive form of PDF document in web image viewer .
Created AspNetCorePdfReaderDemo, which demonstrates how to view PDF documents with ability to navigate bookmarks, view page thumbnails, search text, extract image-resources in ASP.NET Core MVC.
More info please read here: https://www.vintasoft.com/vspdf-dotnet-history.html
What's new in VintaSoft JBIG2 .NET Plug-in 6.0:
.NET development
Added support for .NET Core 3.0 for Windows .
What's new in VintaSoft JPEG2000 .NET Plug-in 5.0:
.NET development
What's new in VintaSoft Document Cleanup .NET Plug-in 4.0:
.NET development
Web development
Created the platform-independent .NET Core web service for processing of document images .
Created ASP.NET Core API controller for processing of document images in ASP.NET Core MVC .
What's new in VintaSoft OCR .NET Plug-in 4.0:
.NET development
The used Tesseract OCR engine has been updated to version 4.1.0.
Created AspNetCoreOcrDemo, which demonstrates how to recognize text from image or image-only PDF document in ASP.NET Core MVC .
What's new in VintaSoft DICOM .NET Plug-in 2.0:
.NET development
What's new in VintaSoft Forms Processing .NET Plug-in 2.0:
.NET development
Post
by Alex » Fri Nov 29, 2019 10:39 am
Version 9.0.0.3 of VintaSoft Imaging .NET SDK has been released.
Fixed the bug in OverlayBinaryCommand class.
Added the ability to select an item in PDF interactive listbox/combobox by pressing the keyboard key that correspons the first item letter.
Improved the memory usage in algorithm that loads XREF table of PDF document.
Fixed the bug in algorithm that packs PDF document, which contains resources compressed with JBIG2 compression.
Fixed a minor bug in PdfPage.ClearImages method.
Fixed the bug in algorithm that decodes image-resources compressed with CCITT3 compression.
Fixed the bug in algorithm that adds empty page to a PDF document in PdfEditorDemo/WpfPdfEditorDemo.
Post
by Alex » Fri Dec 06, 2019 11:55 am
Version 9.0.0.5 of VintaSoft Imaging .NET SDK has been released.
Fixed the bug in algorithm that packs PDF document with image-resources compressed with JBIG2 and text filter.
Post
by Alex » Wed Dec 18, 2019 4:58 pm
Version 9.0.0.7 of VintaSoft Imaging .NET SDK has been released.
Fixed bugs in algorithm that renders pages of DOCX document.
Post
by Alex » Wed Jan 22, 2020 4:26 pm
Version 9.0.0.9 of VintaSoft Imaging .NET SDK has been released.
Added the ability to decode JPEG files with damaged image data.
Added the ability to comment PDF document in WinForms/WPF image viewer:
add and remove comment or reply
create comment threads
set state for comment or reply
display comments on image viewer or in application interface
comments, which are based on PDF markup and popup annotations, are fully compatible with third party PDF viewer applications
Added the support for PDF text and popup annotations.
Increased the performance of algorithm that renders PDF annotation in WPF image viewer.
Added the ability to comment PDF document in PdfEditorDemo/WpfPdfEditorDemo.
Added the ability to get raw data of DICOM data element (DicomDataElement.GetRawData method).
Added the ability to specify that DICOM data elements must not be recoded during saving of DICOM file (DicomFile.RecodeDataElements property).
Fixed the bug in algorithm that extracts text from DOCX document.
Post
by Alex » Fri Jan 31, 2020 11:36 am
Version 9.0.0.11 of VintaSoft Imaging .NET SDK has been released.
Fixed the bug in algorithm that select text on PDF page.
Fixed the bug in PdfOptimizeImageColorDepthCommand class.
Fixed minor bugs in functionality that allows to comment PDF document.
Post
by Alex » Fri Feb 14, 2020 12:05 pm
Version 9.0.0.15 of VintaSoft Imaging .NET SDK has been released.
Fixed the bug in WPF image viewer when viewer is working in multipage view mode.
Optimized work of DemosCommonCode.Annotation.CommentControl control.
Fixed the bug in editor of PDF text interactive field.
Fixed the bug in algorithm that updated appearance of PDF interactive field.
Fixed minor bug in PDF decoder.
What's new in this version of VintaSoft Office.NET Plug-in:
Fixed the bug in algorithm that calculates paragraph index in DOCX document.
Post
by Alex » Fri Feb 21, 2020 12:52 pm
Version 9.0.0.17 of VintaSoft Imaging .NET SDK has been released.
Added the ability to rotate rectangle-based PDF graphics figures (Rectangle, Ellipse, TextBox, FormXObject, Image, VintasoftImage) in image viewer.
Improved the PDF/A converter: added fixup for trigger OverprintModeIs1WhenIccBasedCmykColorSpaceAndOverprintControlUsed.
Post
by Alex » Fri Feb 28, 2020 2:34 pm
Version 9.0.0.19 of VintaSoft Imaging .NET SDK has been released.
Fixed minor bug in JPEG decoder.
Post
by Alex » Fri Mar 06, 2020 12:48 pm
Version 9.0.0.21 of VintaSoft Imaging .NET SDK has been released.
Fixed the bug, which is related with drag-and-drop operation in WpfImageViewer class.
Added new method - PdfDocument.AddDocument(PdfDocument), which allows to add pages and bookmarks from specified PDF document to the source PDF document.
Fixed the bug in algorithm that decodes PDF image-resources.
