Version 12.3 of VintaSoft Imaging .NET SDK has been released.
The new version 12.3 of VintaSoft Imaging .NET SDK and Plug-ins has been released with support for .NET 8 and many more!
What's new in VintaSoft Imaging .NET SDK 12.3:
  • Added support for .NET 8.
  • .NET development
    • Image processing:
      • QuadrilateralWarpCommand class: Added the ability to apply an inverse transformation to an image.
  • Web development
    • Web document viewer:
      • Now WebDocumentViewerJS class can open files hosted on an HTTP server (URL) without uploading the file data onto the application's web server.
      • Added removePage, removePages, swapPages functions into WebDocumentViewerJS class.
      • Added the ability to save changes (reorder pages, annotations, form fields) into WebDocumentViewerJS class (saveChanges function).
      • Added with ability to export images with annotations to PDF or TIFF file.
      • Created new UI-elements for Web controls: WebUiMultiSelectElementJS, WebImageViewerContextMenuJS
      • Created new UI-panels for WebDocumentViewerJS control: WebUiPropertyGridPanelJS, WebExportFileSettingsPanelJS, WebUiImageViewerSettingsPanelJS, WebUiAnnotationCommentSettingsPanelJS, WebUiAnnotationCommentListPanelJS, WebUiPdfRedactionMarkSettingsPanelJS, WebUiPdfRedactionMarkListPanelJS, WebUiPdfImageResourcePanelJS
      • Created new UI-dialogs for WebDocumentViewerJS control: WebUiPropertyGridDialogJS, WebExportFileSettingsDialogJS, WebImageViewerSettingsDialogJS, WebUiAnnotationCommentSettingsDialogJS, WebUiPdfRedactionMarkSettingsDialogJS, WebUiPdfImageResourceDialogJS
    • Web thumbnail viewer:
      • Added the ability to rearrange thumbnails using the drag-and-drop operation. Image
      • Added the ability to navigate thumbnails using keyboard.
      • Added the ability to select thumbnails using keyboard.
      • Added the ability to delete thumbnails using keyboard.
    • Demo applications:
      • The code of the web demo applications has been refactored to make it more simple.
    • Added many improvements.
    • Fixed many minor bugs.
  • See the changes history for plug-ins related with this version of VintaSoft Imaging .NET SDK following a link below:
What's new in VintaSoft Annotation .NET Plug-in 12.3:
  • .NET development
    • Added the ability to create a digital signature based on an annotation, and sign a PDF document using the digital signature.
      • AnnotationDemo and WpfAnnotationDemo were added with ability to create a digital signature based on an annotation and sign a PDF document using the created digital signature.
    • Fixed several minor bugs
  • Web development
    • Added the ability to comment annotations in web document viewer.
What's new in VintaSoft PDF .NET Plug-in 9.3:
  • .NET development
    • Added the ability to work with linearized PDF documents:
      • Added the ability to check whether a PDF document is linearized.
      • Added the ability to create a linearized PDF document.
    • Added the ability to embed information for long-term validation (LTV) of digital signature into a PDF document.
    • All resources from Vintasoft.Imaging.Pdf.Resources.dll assembly were moved into Vintasoft.Imaging.Pdf.dll assembly. The Vintasoft.Imaging.Pdf.Resources.dll assembly has been deleted.
What's new in VintaSoft Document Cleanup .NET Plug-in 7.3:
  • .NET development
    • Created the DocumentPerspectiveCorrectionCommand class, which allows to correct the perspective distortion of document image in .NET.
  • Web development
    • Created the WebDocumentPerspectiveCorrectionCommandJS class, which allows to correct the perspective distortion of document image in Web.
What's new in VintaSoft Office .NET Plug-in 4.3:
  • .NET development
    • Added the ability to work with CSV and TSV files:
      • Now the XLSX file decoder can open CSV- and TSV-files.
      • Added the ability to convert an XLSX file to a CSV- or TSV-file and vice versa.
    • Implemented all graphic shapes, which are predefined in Office.
      • SpreadsheetEditorDemo and WpfSpreadsheetEditorDemo were added with ability to open CSV- or TSV-files.
      • SpreadsheetEditorDemo and WpfSpreadsheetEditorDemo were added with ability to export an open XLSX document to CSV- or TSV-file.
    • Fixed several minor bugs.
  • Web development
    • The ability to set a new or edit an existing hyperlink (URL hyperlink or cell hyperlink) has been added into WebSpreadsheetDocumentEditorControlJS control.
      • SpreadsheetEditorDemo can now open СSV- and TSV-files.
What's new in VintaSoft OCR .NET Plug-in 7.3:
  • The used Tesseract OCR engine has been updated to version 5.3.3.
  • Now all text blocks received from the image segmentation command are marked as blocks of RecognizeSingleColumn type. Previously, these blocks were marked as blocks of RecognizeSingleBlocks type. This change increased the quality of text recognition for complex text and did not reduce the overall performance of text recognition.
What's new in VintaSoft DICOM .NET Plug-in 5.3:
  • .NET development
What's new in VintaSoft JBIG2 .NET Plug-in 7.3:
What's new in VintaSoft JPEG2000 .NET Plug-in 8.3:
What's new in VintaSoft Forms Processing .NET Plug-in 5.3:
Version 12.3.1.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
      • Improved the algorithm that renders documents in vector mode. Now the algorithm renders a document in vector form only if the document can be optimally rendered as SVG content.
      • Improved the dialogs.
      • Improved the main and mobile menus.
      • Fixed several bugs.
    • Demos
      • AspNetCoreFileConverterDemo: Added the dialog for DOCX/XSLX decoder settings.
      • Improved the UI localization in ASP.NET Core demo projects.
  • .NET development
    • Added the ability to enter any character into a PDF interactive text field. Previously it was possible to enter only those characters, which are present in the font that is associated with the text field.
    • Improved the algorithm that parses Type0/TTF fonts.
    • Improved the algorithm that converts PDF to SVG.
  • .NET development
    • Improved the algorithm that renders XLSX chart.
    • WinForms/WPF spreadsheet visual editor
      • Added the ability to change labels for chart axes.
  • Web development
    • Web spreadsheet visual editor
  • .NET development
    • Updated the list of DICOM tags and DICOM UIDs in compliance with DICOM 2023 specification.
Version 12.3.2.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • Improved the thumbnail selection in web thumbnail viewer.
    • Improved the algorithm that renders stamp-annotation.
    • Added improvements in code of AspNetCoreFileConverterDemo project.
  • .NET development
    • Added the ability to add several signatures to PDF document. The evaluation version makes all existing digital signatures of PDF document invalid if new digital signature is added to the document.
    • Improved the algorithm that parses ICC profile.
  • .NET development
    • Added the support for HorizontalMerge tag in DOCX table.
    • Fixed the bug in algorithm that loads DOCX/XLSX document.
Version 12.3.3.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Image processing:
      • Improved the algorithm that processes color image in GetRotationAngleCommand class.
      • Added the Binarization property to the GetRotationAngleCommand class.
    • Image codecs:
      • Added an improvement in TIFF encoder.
      • Fixed the bug in parser of ICC-profile.
    • Image viewers:
      • Fixed the bug in WpfImageViewer.ImageAnchor property.
      • Added improvements to the code of CameraBarcodeReaderDemo project. Now the project uses Vintasoft.Barcode.CameraBarcodeScanner class to recognize barcodes from camera.
      • Added improvements to the code of PdfCompressorConsoleDemo project.
  • Web development
    • Increased the image rendering performance in web image viewer while loading images from URL.
      • Added the ability to display images from several files.
      • Added the ability to clear cache for HTTP session.
      • Added the ability to resize side panel.
    • Web image viewer:
      • Improved the rendering of web image viewer when web browser displays web page with scaling.
      • Improved the rendering of web thumbnail viewer when web browser displays web page with scaling.
      • Added the ability to select thumbnails using checkboxes.
      • Added the ability to display action menu for thumbnails.
  • .NET development
    • Improved the parser of PDF document.
    • Improved the algorithm that restores document information for broken PDF document.
    • Fixed the bug in PDF renderer.
    • Fixed the bug (regress) in PDF/A converter.
  • .NET development
    • Fixed bugs in SpreadsheetVisualEditor class.
  • Web development
    • Web spreadsheet document editor control:
      • Added the ability to work with defined names in XLSX document.
      • Improved the quality of rendered XLSX page when web browser displays the web page with scaling.
  • .NET development
    • Added the ability to disable cycling of slides while browsing slides using DicomViewerTool or WpfDicomViewerTool visual tool.
What's new in this version of VintaSoft Document Cleanup .NET Plug-in:
  • .NET development
    • Improved the algorithm that processes a color image in DeskewCommand class.
Version 12.3.4.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that parses TTF font.
  • Web development
    • Added the ability to scroll web thumbnail viewer when thumbnails are dragging in viewer.
    • Improved the error handling in HttpStreamingStream class.
  • .NET development
    • Added CreateLossyCompressor and CreateLosslessCompressor methods to the PdfDocumentCompressorCommand class.
    • Improved the algorithm of PdfDocumentCompressorCommand class.
    • Fixed the bug in algorithm that parses 16-bit grayscale image-resource.
    • Fixed the bug in algorithm that packs TTF font.
  • Web development
    • Class WebUiEditDefinedNameDialogJS is renamed to WebUiAddDefinedNameDialogJS.
    • Fixed some minor bugs.
Version 12.3.5.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • Fixed minor bugs in web thumbnail viewer.
  • .NET development
    • Fixed minor bug in algorithm that analyzes regions of recognized symbols.
Version 12.3.6.1 of VintaSoft Imaging .NET SDK has been released.
  • Web development
    • Improved the algorithm in VintasoftFileApiController.CopyFile method.
Version 12.3.7.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that parses image-resources in PDF document.
Version 12.3.8.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
Version 12.3.9.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed regress in algorithm that allows to drag-and-drop files to ThumbnailViewer class.
  • Web development
    • Fixed minor bug in algorithm that allows to navigate images in WebImageViewerJS class.
  • .NET development
    • Now PdfEncoder class can convert PDF document without structure tree to a PDF/A-1a, PDF/A-2a or PDF/A-3a document. Previously only a PDF document with structure tree could be converted to a PDF/A-1a, PDF/A-2a or PDF/A-3a document.
    • Decreased the memory usage when SDK renders PDF page with a lot of graphical content.
