Code samples
Code samples for VintaSoft PDF .NET Plug-in. Here you can request a code sample.
Board index < VintaSoft Imaging < VintaSoft PDF .NET Plug-in Discussions < Code samples
Check whether values of PDF form fields have been changed.
If you want to check whether values of PDF form fields have been changed, you need to do the following steps:
  • Get and save information about field values before editing of PDF form.
  • Get and compare information about field values when you want to determine changes in PDF form.
Here is C# code snippet that shows how to check whether values of PDF form fields have been changed:
Dictionary<PdfTreeNodeBase, PdfBasicObject> _fieldValues;
/// Checks whether values of PDF form fields have been changed.
public void CheckFieldsAreChanged(PdfDocument document)
    Dictionary<PdfTreeNodeBase, PdfBasicObject> newFieldValues = GetFieldValues(document);
    if (_fieldValues != null)
        if (AreFieldValuesChanged(_fieldValues, newFieldValues))
            MessageBox.Show("Changed");
    _fieldValues = newFieldValues;
/// Returns a value indicating whether values of PDF form fields have been changed.
public static bool AreFieldValuesChanged(Dictionary<PdfTreeNodeBase, PdfBasicObject> fieldValues1, Dictionary<PdfTreeNodeBase, PdfBasicObject> fieldValues2)
    if (fieldValues1.Count != fieldValues2.Count)
        return true;
    foreach (PdfTreeNodeBase field in fieldValues1.Keys)
        PdfBasicObject value1 = GetValue(fieldValues1[field]);
        if (!fieldValues2.ContainsKey(field))
            return true;
        PdfBasicObject value2 = GetValue(fieldValues2[field]);
        if (value1 == value2)
            continue;
        if (value1 == null || value2 == null)
            return true;
        if (value1.ToString() != value2.ToString())
            return true;
    return false;
/// Returns dictionary that contains values of PDF form fields.
public static Dictionary<PdfTreeNodeBase, PdfBasicObject> GetFieldValues(PdfDocument document)
    Dictionary<PdfTreeNodeBase, PdfBasicObject> result = new Dictionary<PdfTreeNodeBase, PdfBasicObject>();
    if (document.InteractiveForm != null)
        foreach (PdfInteractiveFormField field in document.InteractiveForm.GetTerminalFields())
            result.Add(field, ((PdfDictionary)field.BasicObject)["V"]);
    return result;
/// Returns value of PDF form field.
private static PdfBasicObject GetValue(PdfBasicObject basicObject)
    if (basicObject is PdfIndirectReference indirectReference)
        return PdfIndirectObject.GetByReference(indirectReference).Value;
    return basicObject;
